confusion about wheel adaptors
Old Oct 7, 2002 | 07:32 AM
97-1LE's Avatar
Car: 87 Trans Am
Engine: Built 350 Cam, Headers
Transmission: 5 speed
I've read many post about wheel adaptors, and the more I read, the more confused I get. I see people using adaptors from 1 inch to 2 .5 inch adaptors. What is the correct size adaptor to use with a 4th gen 16 X 8 Trans Am wheel going on a 87 Trans Am with a drum brake rear ? Should the front adaptors be different than the rear?
Old Oct 7, 2002 | 11:28 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
If I remember correctly I happilly used 1.25" in the rear
and 2.25" on the front.
Some people are using 2" all around.
Another option for the rear, is to get a 4th gen rear, and not use any spacers at all for the rear. Thats what I have done (did the spacers first, the swapped the rear) I got my 3.42 posi disc rear for $300. thats pretty close to the price of 4 spacers.
Hope I helped.
Old Oct 7, 2002 | 09:51 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
to get perfect thirdgen backspacing and offset (for 16" wheels) on fourthgen 16x8 wheels, you would need 2.15" spacers front, and 1.5" spacers rear. With a drum rear, you'd actually need more like a 1.65" spacer rear, since there is a thin spacer when using 16" wheels on a drum rear from the factory on thirdgens.
I'm running 2" all around, and i think it looks good that way.
I'd recommend the 2" all around or just swapping to a fourthgen rear setup since you do have drums in back.
Old Oct 7, 2002 | 09:59 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
I'm running 2" on all 4 corners.
Old Oct 8, 2002 | 12:38 AM
FLYNLOW92rs's Avatar
I'm also running 2" adapters all the way around and no problems with them (knocking on wood)............I'm running aftermarket rims though....
Old Oct 8, 2002 | 07:01 AM
97-1LE's Avatar
Car: 87 Trans Am
Thanks for the quick replies. Any one have any 2" adapters they would like to sell for a modest price?
Old Oct 8, 2002 | 10:50 AM
86FyrBrd's Avatar
Heres a set
http://www.fbodytrader.com/forum/ind...t=ST&f=11&t=51
Jorlain
Oct 8, 2015 01:57 AM
Numbah-1
Sep 12, 2015 08:57 PM
Blue419
Sep 10, 2015 01:03 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
