good engine\brake caliper (any anything else cast iron) paint..
Old Nov 13, 2002 | 11:05 PM
breathment's Avatar
i got some Krylon Rust Tough Enamel PRIMER. and some Dupli-Color Ceramic Engine Enamel PAINT (red)..
and i painted my calipers. i cleaned them up and got all the rust off and all that good stuff. and i sprayed the primer on. and it went on perfectly. like a beutiful coat that was smooth and all that. went on very nice. so i thought that the actual paint would go on just as nice. so i spray it on. and its runny and doesn't go on nearly as thick as i though it should. its really runny and crappy.. and takes alot of coats to look nice.. i can't see how u would want to paint an entire engine with this stuff. am i missing out on a step or something. what is some better stuff out there?
Old Nov 13, 2002 | 11:50 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I've used Duplicolor on the 350 block I'm building and I had no problems.
I have to say I cheated a little though.
First I cleaned the block, then masked it off. I didn't primer it because I never have before. Then I sprayed some of the paint into a cup and blotted the engine with those sponge type brushes you can get at Menards. I just dipped and blotted, dipped and blotted, etc. Then after I let that sit overnight.
Blotting it on like that left it really dull, but it covered well and didn't flake off. Next I sprayed it with a real light coat to give it it's shine back. It's looks great and didn't take long. I don't know how it's gonna hold up to heat, but we'll see if I ever get the damn motor put in.
AJ
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Jan 19, 2016 12:21 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
