Wet Sanding
Old Nov 18, 2002 | 08:54 PM
91 z28 350's Avatar
Car: 91 Z28
Wet Sanding
Ok i bought a plenum off ebay and i want to polish it when i get it so how do i go about wet sanding just use water or wd-40 and just keep it constently wet ?
Old Nov 18, 2002 | 08:57 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
yeah..use lots of water keeping it wet and go at it.Never heard of the WD-40..interesting
Old Nov 18, 2002 | 08:59 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yes, WD 40 will be better than water, I didn't have any around so I used some carb cleaner I believe, or something like that.
Old Nov 18, 2002 | 09:04 PM
EvilCartman's Avatar
Car: '82 Z28
Water with some soap mixed in.
Old Nov 18, 2002 | 09:07 PM
91 z28 350's Avatar
Car: 91 Z28
k i'll try all 3 of them it couldn't hurt right ?
Old Nov 18, 2002 | 10:07 PM
Car: 99 Formula
Axle/Gears: 342
Never heard of water and soap, I'd like to use something that will remain clear helps to see, ya know.
Old Nov 18, 2002 | 10:43 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Mark used Maple syrup when he did his.
Old Nov 18, 2002 | 11:04 PM
Car: 99 Formula
Axle/Gears: 342
and you used **** lube.
Old Nov 18, 2002 | 11:09 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I used just lots of water when I did my rims... they came out good. But when I polish my LT1 Intake, I'll probably try out the WD40 technique.
Old Nov 19, 2002 | 02:47 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Is there a certain type of sandpaper to use? Like specifically for wetsanding.
Old Nov 19, 2002 | 04:40 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
KY does wonders!
Old Nov 19, 2002 | 04:42 PM
Car: 99 Formula
Axle/Gears: 342
I believe 1500 or higher, I used 1500.
Old Nov 19, 2002 | 05:21 PM
JACKO's Avatar
Yes! wet rub paper from the auto paint stores etc coz normal paper will fall apart & wetrub paper comes in very fine grades
Hotrodboba400
Dec 10, 2019 07:07 PM
92-Formula
Dec 12, 2015 10:34 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
