Compounding and Detailing
Old Dec 23, 2002 | 11:18 PM
1989TransAm's Avatar
I need opinions of which buffer I should get. My auto shop teacher in school uses an older Makita, the 90 degree pro one. I just started with learning out to detail my car, I would like to purchase my own buffer. I heard that Portar Cable makes a good one. Which one would you recommend, in which it won't be as easy to burn through the paint, but still get amazing results. Also I plan on using Gliptone Show Gloss, and 3M Rubbing compound. I plan on working on the hood first, any advice on working on it? Should I tape off the plastic hood vents? Also, is it safe to wetsand the entire hood? Basically if someone could give me a basic run down of which order I should do what in, I would appreciate it. Also, what can I use for the front bumber, I heard you can't use compound.
Linson
Oct 24, 2025 02:00 PM
F-body-fan
Jan 12, 2023 01:49 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
