FINNALLY got around to cleaning the engine
Well here is my 1st attempt at cleaning my engine.. still needs a little work .. but i just thought that i would show my progress .. i want to get all braided steel hoses for it and some chrome to make it look pretty =o)
https://www.thirdgen.org/techbb2/sho...hreadid=150618
heres what it went from .. not bad if i say so myself =o)
Car: 99 Formula
Axle/Gears: 342
Throw that air cleaner away now. I and several others have had a carb backfire, and it melts and gets sucked right into the carb.
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Originally posted by vortech305
never understood why people had a thing for braided hoses?
Anyway get an open element.....
Just nice job nonetheless, I need some motivation to clean out mine.....
Car: 99 Formula
Axle/Gears: 342
The real braided hoses look great IMO.
Car: '82 Z28
I replaced my fuel lines with steel braided line after the regular rubber lines split open. Expensive stuff but worth the quality and safety. Senior Member
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
Originally posted by fast83camaro
What is this belt turning?
kinda looks like its turning an air pump, I dunno, I wouldnt think a carbed engine would have one.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by deadbird
It does turn the AIR pump. My 84 LG4 (q-jet 305) & 87 LB9 (TPI 305) both had that outermost pulley groove on the water pump to turn the AIR pump.
really.. I would have never thought a carburtated motor to have an air pump, does it pump the air into the manifolds or just the cat? or am I wrong on both accounts?
the haynes manual explains how it works .... i think from what i understand is that it will pump air into the cat until it warms up then push the air through the exhaust. I dunno, its confusing ..... very inefficent ... and clutters up the engine bay. 70's smog reducing ideas that were still in effect.
Looks better, what solutions did you use? Just water? When i cleaned mine i used a degreaser and simple green.
And yea, that air filter is bad news. YOu can get a spectre 14x3 open element for 15 bucks. It will make it look better and i'd feel safer using that. Not only does it melt if your carb backfires. But after awhile the foam breaks apart and gets sucked in.
db057
Aug 11, 2015 10:11 PM
