Check out my friends Camaro
Old Jan 16, 2003 | 03:11 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
, This is my good friends 91 Camaro RS. Has the SS hood, an LT1 with the LT4 package on it and some other goodies , a built 700r4, and 3.73's with an Auburn posi unit. Should be a good low 13's to high 12's in the 1/4 we hope. Just got done helping on the engine swap. That was fun.
Old Jan 16, 2003 | 03:13 PM
Camrs89's Avatar
Another...Sorry about the pic being crooked. I'm terrible with the scanner!
Old Jan 16, 2003 | 03:16 PM
85_ZED28's Avatar
Car: '85 Z28
thats a beautiful car, and an LT1? :hail: :hail: :hail:
Old Jan 16, 2003 | 04:13 PM
Kandied91z's Avatar
sharp looking ride!!
some days i wish i didn't purchase a 91 so i could feel all right buying that hood.....some days.
Old Jan 16, 2003 | 04:29 PM
Ragtop89's Avatar
Tell us more!
How long did it take to do the swap?
What kind of crap did you have to fab up?
Was the wiring easy?
Did you have to change the engine mounts?
INFO!!
Old Jan 16, 2003 | 04:30 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
oh wow.. makes me want to buy a vert even more..
beautiful car!
Old Jan 16, 2003 | 04:35 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
NICE Ride!!!!
Is that a stock paint job?
Ken
Old Jan 16, 2003 | 08:25 PM
MdFormula350's Avatar
very nice!! any engine pics?
Old Jan 16, 2003 | 08:34 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Wow...that is really sharp@..what kind of exhaust is he running on it?
Old Jan 16, 2003 | 08:37 PM
Camrs89's Avatar
"Tell us more!
We started around Dec. 15 or so. Worked on it mostly mornings because we we using someones garage. Just finished last Sunday
Ummm..alot, probably forget some stuff, but new raditior (reverse flow), move the motor mounts a bit, starter, fuse box, make a mount for the computer, reprogrammed the computer since VATs were an issue had to buypass that, new fuel system, A/C still not hooked up but needs to be installed and brakets made to wor
NO!! Although we tried to save some money since most was spent on unexpected parts, we used the LT1 wiring harness instead of the Painless wiring kit. Had to do ALOT of wire work and I DO NOT recommend using this if someone wants to go through this. Use the Painless kit.
Just had to move them. Seemed like a b$tch until we reached the wiring and wished everything was easy as that seemed. The hardest part of the swap was getting all the wiring done. I recommend the kit stongly.
"Is that a stock paint job?"
Ummm...about 1/4 of it is. Its been sideways before and my friend lost control and hit a guardrail so one side was repainted. It matches up perfectly and the fact that we are both detailers doesnt hurt either!!
Old Jan 16, 2003 | 08:39 PM
Camrs89's Avatar
He right now has a 3 inch exhaust with a Flowmaster, but we are looking for something a little more efficient with the engines power. It has a cam, head work, headers, no emmisions, and some other tweaks on it.
Old Jan 17, 2003 | 12:56 AM
Kandied91z's Avatar
that exhaust with a good header is more than sufficient up to 350-400 range...above that you'll definately want to go 4".
Old Jan 21, 2003 | 09:52 PM
HrdRockA4305's Avatar
So its drivable now? Badass! He's proabbly back at SIU by now though. Dude, you've dropped off the face of the earth lately where the hell you been? ( I guess this explains part of it dosen't it)
Old Jan 21, 2003 | 11:31 PM
Camrs89's Avatar
No money and no car make Mikey go crazy!!!! LOL
Just been working alot and going to school. I usually have THursdays and Fridays off though. I also want to blame it on the fact that its too cold to really do any of the things we like!
Old Jan 22, 2003 | 12:31 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Hope you guys did some chassis/suspension mods to handle the kind of power an LT1 delivers but a stock RS would be seriously pressed to handle. I own a 91 vert and have been making various changes in these areas to accomodate the 350 TPI that will be dropped in this summer.
So far, I've done SFC's, struts/shocks, Eibachs prokit, and WS6 front/rear sway bars, steering brace, STB, plus poly-bushings at strategic locations. (I think she'll hold).
Has your friend done any more or any less to his ride for handling?
Also do you know if he did any braking mods to stop that beast? I can't afford a new Baer brake sys., so I'll just get some heavy durty pads/ shoes for the discs/ drums.
SOrry to ask you to answer all these q's on your friends behalf, but the info would really be appreciated!
Old Jan 22, 2003 | 02:37 PM
Camrs89's Avatar
So far its lowered 1 1/2 or 2 inches (I forget), the pics where taken before the lowering. Hotchkis lowering kit and wider tires. Other than that stock suspension so far. He plans on subframes and seeing if a strut tower brace will work. A roll bar will also be put on this summer. The car is being done paycheck to paycheck. I just keep telling him dont abuse it without subframes at least.
Old Jan 22, 2003 | 05:29 PM
Let me say this: With a 305 and stock suspension (besides Prokit), I threw down the hammer off the line and it felt like my ***-end did not know which way to go. When my rear finally figured out that it needed to go "straight" to win, the race was already over.
Mind you I have a vert too. BUt mine is a Z28, which I think may be 1 step above the susp of an RS vert.
SFC's made a HUGE difference. Got mine from restoreclassics.com ($150 parts, $30 install).
Then I walked around salvage yards until I found a 36mm front and 24mm rear sway bar. INstalled those with a Global West steer brace.
TOTALLY different car. You point, it goes. Thats all I can say. No body twist or hesitance. All the energy lost in the chassis flex and roll goes straight back to the wheels.
Anyway....
Old Jan 25, 2003 | 04:56 PM
Camrs89's Avatar
We will have new pictures to post of the car and the engine bay next weekend. Also get to test her out too!! Will post details later.
Old Jan 25, 2003 | 05:24 PM
Camrs89's Avatar
I just got off the phone with my friend. He says he has adjustable shocks and stuts, lowered 1 1/2, underdrive pulleys, ported LT4 heads and intake, a TCI racing rebuild kit (700r4) and the engine was tested out and brought up to 7500 rpms and still was pulling without any trouble. The mechanic that was helping us says he expects 500 HP at the flywheel and says the car will go sideways into 4th gear! He is looking for a mid 80's gauge cluster for a Camaro so he can put aftermarket gauges in it. Email me if you have on laying around. Thanks
Old Jan 28, 2003 | 11:07 PM
There should be a couple at Darst. There is also that Z28 down there that I was gonna yank the swaybars from. Well, won't be needing those.... but they'd probalby be nice on Travis's car! Hardtop and 'vert swaybars are the same right?
Old Jan 30, 2003 | 12:38 AM
Nope: Z28 vert sway bars are 21mm rear and 32mm hollow front.
Not sure about RS verts (maybe 19 and 30)......
WS6 and Z28 coupe should be @ 36mm front hollow and 24mm rear.
Old Feb 3, 2003 | 12:36 AM
Do they use the smaller ones so its less stress on the frame? I'd assume so, since a 3G converatble's frame isn't exactly rigid.
Infested
May 22, 2018 11:56 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
blackd-out z28
Aug 15, 2015 08:18 PM
gwade12
Aug 8, 2015 08:17 AM
