18s and a one inch drop
Old Jan 25, 2003 | 04:06 AM
TA88GTA's Avatar
Im looking in to picking up a set of 18inch torq thrust 2s for my 88 trans am and just wanted to know if i might run in to any clearance problems because my car has a one inch drop. Also if you guys could provide me with the optimal rim width and backspacing it would be greatly appreciated. thanks
Old Jan 26, 2003 | 09:28 PM
TA88GTA's Avatar
Anyone???
TTT
Old Jan 27, 2003 | 04:04 AM
CrazyHawaiian's Avatar
Car: too many ...
Powermite ran 265/40/zr18's in the front with a 1" drop. He said it didnt rub unless you were at full lock. Driving was fine. I dont know what the optimal width would be (and the offset would depend on the width), I guess it depends on how much you want to modify your wheelwell to accomidate your drop. One inch drop isn't too low to run 18" wheels. For the best fitment I went with something close to stock width on the front. My 18's are 18x8 front (4.5 backspace just like stock) and 18x9.5 rear (5.5 backspacing) and I plan to run 245/40/zr18 front and 275/40/zr18 rear. Its possible to go with wider tires, but I want a setup that I can slam at shows (adjustable suspension), tuck the wheels deep into the wheelwells, and requires minimal fenderwell modification. Some might consider optimal being the widest possible, I consider optimal being the best fitment that requires minimal fenderwell modification. If you want to go really wide, you could roll the lip on the rear and run 265/40 fronts and 295/40 rears. Depends on how much work you want to put into it. Hope this helped ...
Old Jan 27, 2003 | 12:05 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
On my 85 T/A i've got the GTA gold crosslace wheels with no drop and 255/50's all around and they rub quite a bit, Is there anything i can do to make them not rub so much or just get smaller wheels or tires? thanks
Old Jan 27, 2003 | 03:41 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
I have indeed 18"s with 265/40x18" and ive lowered the car with edelbrock springs.9"wide front and 10"rear.
I am actually about to change these to 245/45 x 18"fronts and 275/40x18" rears therefore keeping the front and rear diameters the same.
I just felt that 265s are a bit wide on my 9"rims and they have a tendancy to wander and "tramline",so i thought maybe 245s would be a little better.
I cant tell you the exact backspacing but i think its about 5"front and 5.5-6"rear.
If you want to know exactly i will soon be taking the wheels off to have the tyres replaced so i'll let you know then.
cheers
PM
Old Jan 29, 2003 | 02:59 AM
TA88GTA's Avatar
Those brakes look sweet with your rims. Where did you get those rotors and how much did you pay? Ive got a complete 1LE set front and rear waiting to go on but i could use some new rear rotors so might as well go to cross drilled and slotted. Also those measurements would be great. thanks
Old Jan 29, 2003 | 10:08 AM
powermite's Avatar
Car: Transam
The brakes are a Baer Kit and they came drilled and slotted.
I'll let you know the other dimensions soon
PM
Old Jan 29, 2003 | 08:37 PM
91FIREBIRDGT's Avatar
Car: 1991 Firebird
Engine: 3.1LV6
On my Firebird I'm runnin on 235/40/ZR18 on my 18X8's all around. they're rapped around some nice lookin wheels. I'll have pics posted ASAP
Old Jun 20, 2003 | 11:16 PM
devianb's Avatar
I like those.
amargari
Nov 10, 2015 02:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
