Parking Lights fogging BAD
Car: 1992 Camaro RS
Engine: 3.1 MPFI
My parking lights, the yellow ones in the front, are so fogged and dripping with water they look so bad. Anyway does anyone know how to remidy this????????
Thanks!
Thanks! Supreme Member
Car: 85 Camaro SC
Engine: V6
There is a tech article on how to cut a slit in your bumper to allow the condensation out of the lens. For some reason gm didnt think of it sooner and fix the problem. BTW thats something I need to do too. My driver is always fogged up but the pass is just fine.
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
Originally posted by 3.1RS
where can you buy new ones and how much do they cost?
they're not much
Car: 88 IROC Convertible
Transmission: Raptor 700
this post should answer your questions about where to get them
https://www.thirdgen.org/techbb2/sho...hreadid=163731
Car: 85 Camaro SC
Engine: V6
Heres the tech article, had to look thru 3 times before I saw it.
https://www.thirdgen.org/newdesign/t...ensation.shtml
Car: 1992 Camaro RS
Engine: 3.1 MPFI
has anyone tried this i was wondering if it worked? And if the possibility arrises that i have to buy new ones, what keeps the it from happening again?
And so i understand right, i cut a small slit in the plastic below the light so the water drains out?.
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
go to my website and see what i did with my lights.....you can try the cut thing but thats not going to help you get the water thats inthere out now...it will only prevent the wind (while driving) from shooting the water up into the hole in the lights thats right above the cut you make,,and only preventing any more water from getting in there ,,,not to get the water out. You could try a hair dryer in the light hole if you want but i bet most of your problem is the lens,,,they get sratched and foggy looking even tho its not fog its just crappy plactic lens that deteriorates over time. The new lights at the dealer are expencive I think,,,Like 100bucks for 2 lights is too much. I made my clears for less then 20 bucks. Cheack em out, I got a tech artical on them on page 6 I think. But if you got 100bucks for new lights and you want that stock look,,,go for it!
http://www.cardomain.com/id/jcurrieirocz
Car: 1992 Camaro RS
Engine: 3.1 MPFI
that doesn't look too bad but i have to say i like the stock ones better, but it certainly doesn't justify paying 100 bucks. if anyone knows how to fix the ones i have now please feel free to post or if anyone has tried the cut thing, post.
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
well mostly all the sport coupes have the ugly amber front parking lights and i hated them....they didnt make any clears for them.....so i made them for about 15 bucks.....and best of all they havent clouded up yet...
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Engine: LG4
basically i took my old amber ones...cut off the amber part....took some 87 clear ones.....took out the clear bumpy thing in it.....grinded it down to size to fit in my housings....then put a piece of plexi over that.....siliconed it up......masked off a line on front to cover up where it was siliconed.......thanks by the way
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Bought me a new set from Classic Industries...ran me $94.00...I wouldn't say they were "cheap"...well worth the money though...they look fantastic
