Anyone else have rubbing with ZR-1's
Old Mar 1, 2003 | 01:28 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Got my 17" ZR-1 wheels on today and I'm pissed. They frikin rub! I did it right too, got the 2.25" adapters from skulte design and they still touch. Anyone else have that problem?
Old Mar 1, 2003 | 05:51 AM
BORLAZ06's Avatar
im purdy sure ur gunna have to massage the inner fender well.
Old Mar 1, 2003 | 09:04 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
yes, I have 2.25 in the front and they still rub just slightly. Nothing terrible, but at very sharp turns or going off of curbs and turning, I can hear it scrape.
Old Mar 1, 2003 | 10:21 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
ok, cool, well not really. Atleast I'm not the only one. Where does is rub? On the metal frame or just on the plastic?
Old Mar 2, 2003 | 06:43 PM
BOTTLEDZ28's Avatar
Transmission: A4
I have no rubbing what so ever on my car and I have the same spacers you all have. If anything the RR tire smashesinto the quarter panel when i hit a big bump. It puts a huge slice in the tire soI had to curl thelip up a little. But again. as for the fronts , its all good. Im running 275/40/17 Nitto up front and 285 in the rear
Old Mar 2, 2003 | 09:10 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
did your car come from the factory with 14" or 15" wheels?
if so, it's perfectly normal if they rub on full lock, because the steering box was never intended for tires that wide. IROC's, Z28s, GTA's, and TA's with 16 inch wheels came with a steering box that doesn't turn as far on full lock. just something you'll have to deal with or swap the steering box.
Old Mar 2, 2003 | 09:47 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
BOTTLEDZr28 lets see some pictures of your car I don't ever think I have seen it! Sounds like a bad ride
Old Mar 2, 2003 | 10:45 PM
BOTTLEDZ28's Avatar
Transmission: A4
I will be getting some pics of my ride on the site asap. It is a bad *** ride and I want to show it off but moter nature doesnt look like shes gonna help me out here any time soon. Thereis still snow on the ground and now its pouring.
Old Mar 4, 2003 | 06:59 AM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
I have the SLP 17X9 ZR1 style SS wheels with 285X40X17 BFG's
and I use 2in. addapters.
They only rub on the sway bar if I turn to the lock.
Old Mar 4, 2003 | 07:06 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
you talkin the real 17x11 ZR1's or the 17x9.5 ones? if you could remotely fit the 17x11's with some massaging, im interested. that would look mean!
Old Mar 5, 2003 | 07:46 PM
chymos's Avatar
Interesting note regarding the rubbing issue for the steering boxes....
my 87 'bird has 15"....and in the rear glove box (in the cargo area) I found a service receipt. when the car was new, the original owner, just after buying the car from the dealer, took it back 'cause the tires were rubbing on sharp turns! dealer put a note on the invoice that that was normal.
MrPackstin
Oct 25, 2017 08:09 PM
Veaceonee
Sep 29, 2016 08:15 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
