Polishing Gta Rims
Subscribe
Mar 2, 2003 | 07:54 PM
I need some advice on how to polish the aluminum part of my GTA rims. I need to know what kind of buffing wheel and compound to use
heres a pic of them
Reply 0
Mar 2, 2003 | 07:55 PM
As you can see they are pretty dull.
Has anyone ever used that steamer cleaner to get brake dust off their rims?
Reply 0
Mar 2, 2003 | 08:22 PM
Those look pretty bad... You will need to sand them first, then use some brown rouge.... You have an air grinder? If not, a drill and a buffing pad will work, but not as good and it will take alot longer. Try some 400 grit paper, then 600 , then try buffing, that should work. You will need to use a white rouge after you are finished with the brown. Do not use the same buffing wheel with both compounds... Am I making sense here?
Reply 0
Mar 2, 2003 | 09:37 PM
they are really dirty right now, when i clean them up with brake dust remover they look better, after that its pretty much just blemishes and dull aluminum
Reply 0
Mar 2, 2003 | 10:11 PM
If it is just blems... then don't sand them... Try buffing them first with the brown bar. If it is not coming out (the shine) , then you "may" need to sand them.
Reply 0
Mar 2, 2003 | 10:12 PM
Whats the name of this brown bar and where can i get it,
what kind of buffing wheel should i use?
Reply 0
Mar 2, 2003 | 10:21 PM
Try a good hardware store, they should at least be able to direct you to a place to get some. I have a few bars here, if you can't find any, I pay 10 dollars a bar and will let you have one for the same. As for the buffing wheels, I use a 1/8" stitch pad for the brown bar, then a loose knit cotton buff with the white bar. After that, just a bunch of hand polishing with Mothers or equal paste.
Reply 0
Mar 2, 2003 | 10:24 PM
Thanks a lot, im about to send the check out for shipping for my plenum, i already sent the TB, is it ok if i put a check in there for $10 and you can send it back with my TB, that way i know i have the right thing
Reply 0
Mar 2, 2003 | 10:34 PM
no problem...
Reply 0
Mar 2, 2003 | 10:37 PM
white bar too? got any extras if you do ill take one
thanks again
Reply 0
Mar 2, 2003 | 10:43 PM
Actually, I will send you half of a brown bar, and half of a white bar... sound good?
Reply 0
Mar 2, 2003 | 10:45 PM
Yeah sounds good. If you could do me a huge favor and just write down some real brief instructions on how to use them i never polished anything before
Reply 0
Mar 2, 2003 | 10:58 PM
i will try to explain.....
Reply 0
Subscribe
