a/c delete pulley pics!!
Old Mar 7, 2003 | 05:02 PM
MdFormula350's Avatar
just got my a/c delete pulley right after i took my engine pics today, so i took some more pics after about 2 1/2 hours installing the pulley and removing the a/c stuff..
enjoy the pics!!
Attached Thumbnails a/c delete pulley pics!!-ac.jpg
Attached Thumbnails a/c delete pulley pics!!-ac2.jpg
Old Mar 7, 2003 | 05:03 PM
Attached Thumbnails a/c delete pulley pics!!-ac3.jpg
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Looks good. Where can I get one?
Old Mar 7, 2003 | 05:04 PM
i know the eninge bay needs a good cleaning but i still need to install the standard heater box next week, when i get it.
http://www.gmpartsdirect.com/
10055890 is the part number
Old Mar 7, 2003 | 05:19 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Hehe, isnt taking pictures fun? I took pictures of everything I could think of when I got my camera :P
Old Mar 7, 2003 | 05:41 PM
Xceleratemaro's Avatar
wow now you can chang your spark plugs....
Old Mar 7, 2003 | 06:25 PM
Nasty_Bird_'90's Avatar
Looks good, Jim. Why does the part# on GMparts direct come up as a water pump pulley?
Old Mar 7, 2003 | 06:35 PM
i dont know, but it works!!
i guess its a multiple purpose pulley
Old Mar 8, 2003 | 12:42 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
does that come with the mounting block as well as the pulley?
Old Mar 8, 2003 | 02:37 AM
Odyssey's Avatar
Uhh dah!
Old Mar 8, 2003 | 03:18 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got a brand new one. I'll sell it for $35 shipped to the lower 48 states. My friend ordered the wrong year A/C Delete pulley.
email me if you want it, zepher@transamws6.com
Old Mar 8, 2003 | 10:46 AM
89firechicken's Avatar
zepher you've got mail
Old Mar 8, 2003 | 10:54 AM
it was a good deal i think for 45 bucks.. brand new and weighs alot less then the compressor.
Old Mar 8, 2003 | 01:26 PM
Zepher's Avatar
I've got a couple of emails, but AOL isn't letting my emails go through to reply. email is NastyBird90@aol.com.
If it's one of you guys, shoot me a pm.
Old Mar 8, 2003 | 03:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
what about that smog stuff? working your way down to the valve covers......
Old Mar 8, 2003 | 04:07 PM
Matt86Z's Avatar
...stainless headers would go a long way to cleaning up the look of that engine bay. Gorgeous ride, otherwise.
Old Mar 8, 2003 | 04:20 PM
does anyone know if the ac delete will work for the somg pump as well?
Old Mar 8, 2003 | 07:51 PM
i am working on the smog stuff right after i finish the a/c delete.
Old Mar 9, 2003 | 05:42 AM
CustomCarShop's Avatar
AC Delete Pulley?
Why wouldnt you just get a smaller belt instead of putting in that pulley thing. Im not trying to be rude or anything, im just curious?
Old Mar 9, 2003 | 10:02 AM
your not being rude at all! however like some people including me i didnt want to cut up anything or relocate it, so i was kinda going for a factory appearing job.. using the right parts to get the job done..
your right though some people have used their creativity and made an successful serperntine setup without using the a/c delete pulley and more pwer to them..
i did things the easy way, i didnt mind spending the money on it to make it look like it came from the factory that way..
Old Mar 9, 2003 | 12:04 PM
SO WILL THE AC DELETE PULLEY WORK FOR THE SMOG PUMP AS WELL?
Old Mar 9, 2003 | 12:32 PM
no for that you buy the smog delete pulley (if they still make it)
Old Mar 9, 2003 | 11:54 PM
BigMike1610's Avatar
Engine: 305 tbi=LO3
Transmission: Automatic
nice job
Old Mar 10, 2003 | 12:56 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
the problem with just getting a shorter belt is the tensioner is right there nest to the AC and you have to have another pulley right by it to bear the main weight of the belt.
Old Mar 19, 2003 | 03:34 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
I just ordered mine. Thanks for the heads up on a good deal. My cost at local Chevy dealer has $51.00. Lists for $65.00.
Old Mar 19, 2003 | 03:42 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
hey guys, for those of you who haven't gotten teh standard heating box yet but installed the pulley, how'd you cap off the ac lines, just use some tape or plugs or what? and also can someone take pictures of the lines that are connected to the radiator? thanks in advance
Old Mar 19, 2003 | 04:34 PM
hey man there are no a/c lines going to the radiator..
you need to take the radiator support off the top then you can pull the big old condensor out
good luck doesnt take long be careful though..
Old Mar 19, 2003 | 04:46 PM
nikh23's Avatar
hmm, so you mean that i just have to unbolt the condensor, remove radiator support, and then just pull all the lines out from underneath and i won't have to plug anything up? Could you take a pic for me if you get a chance, still not sure what you mean
Old Mar 19, 2003 | 06:35 PM
no you unbolt the two bolts and then pull the condensor up out of the engine bay..
all this can be done working in the engine bay, no going under the car....
Old Mar 19, 2003 | 07:32 PM
nikh23's Avatar
oops my fault about that, i was confusing compressor and the condensor. Nevermind i got it now, sorry for the confusion
Old Mar 20, 2003 | 09:02 AM
no problem! good luck..
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
85Special
Sep 3, 2015 04:21 PM
mantaguy
Sep 2, 2015 10:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
