Weld prostars
Old Mar 13, 2003 | 08:20 PM
89irocbeast's Avatar
Weld prostars
Im gonna be buying the weld pro stars this weekend. Does anyone know what size rim for a 275 tire in the back would be? Its and 89 IROC im going to be putting 15s all around. Also what size tire should i get for the front, its mostly always going to used for the strip but im still going to have it on the road
Old Mar 13, 2003 | 08:35 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i would definetly do a 15x10 back rim
Old Mar 13, 2003 | 09:00 PM
I heard that i could fit 295s in the back witout rubbing is that true? But im buying 275s should i get 50 or 60? and what about front tire size and rim size for front
Old Mar 13, 2003 | 09:39 PM
usa1racing's Avatar
I have 295/50/15's out back on what I believe to be 15x8 Cragar Street Stars (were on the car when I bought it) and they dont rub. I dont know the backspace, but the pictures are at: http://www.cardomain.com/id/usa1racing The look is awesome in my opinion.
Old Mar 13, 2003 | 09:54 PM
They look real nice. Now you got me leaning towards buying a pair of 295s. Well now i just need the back spacing, bolt pattern and what size i should get for the front
Old Mar 13, 2003 | 10:00 PM
i would do 295/50-15s on a 15x10 rim out back for sure. a lil beating can take care of any rubbing that could occur. up front it is up to you, how wide and tall of a tire you want up there?
Old Mar 14, 2003 | 05:07 AM
Well i would kinda of like to stay away from beating anyting, its kinda a showy car as well. Upfront im probaly just going to but a 15 but im not sure about width or height, i need some ideas
Old Mar 14, 2003 | 07:13 AM
usa1racing's Avatar
With the 295's that are on the car now, no reshaping of the fenderwell was necessary to make them fit.
Old Mar 14, 2003 | 09:13 AM
Well i was just looking at the tires im getting for the back and the BFgoodrich comp t/a drag radials dont come in 295/50/15 they only have 295/65/15 so i think im just going to have to stay with the 275s DAMMIT!! Still lookin for numbers for a front tire size gimme some help
Old Mar 14, 2003 | 01:50 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
They're okay. Not my favs but not horrible either.
Old Mar 14, 2003 | 01:55 PM
cvpde37's Avatar
I'm running 275 60 15 on the rear on 15 x 8 weld prostar with 4.5" of backspacing and have never had a rubbing problem. The fronts are 215 70 15 on a 15 x 5 weld. I don't have any pictures published anywhere that you can look at right now but could email you one if you would like.
Old Mar 14, 2003 | 05:47 PM
Does anyone think its possible to run a 295/65/15 in the back without having to beat anything?
Old Mar 14, 2003 | 07:21 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
295/65R15 is pretty tall....You "might" be able to fit it.....but 295/50R15 come in BFgoodrich radial T/A....they're in summit all the time....yaya
Old Mar 14, 2003 | 11:04 PM
Yea i kno they come in the radial t/as but i need a drag tire
Old Mar 15, 2003 | 09:29 AM
What is the bolt pattern
Old Mar 15, 2003 | 10:46 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
I'd go for 15 x 4s in the front and 15 x 10s with drag radials on the back....
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
