I made a CAI
Old Mar 18, 2003 | 01:44 PM
Adam62083's Avatar
I made a CAI
Its not done yet. The PVC is temporary, will be painted black until I get a piece of metal tubing to take its place. I dont like how heavy the PVC is.
Anyways here are some shots of it installed in the car. The pieces are pretty heavy duty stuff, cost total about 25 bucks.
And my badass polishing job once again
Old Mar 18, 2003 | 01:48 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Looks good. Should look much better when painted black and even better when you replace it with metal. Is the metal going to be polished also?
Brian
Old Mar 18, 2003 | 01:49 PM
Adam62083's Avatar
Yeah I will try and get aluminum so I can polish that piece.
Old Mar 18, 2003 | 03:59 PM
G92 IROC's Avatar
Nice,
too bad i'm not speed density...
i would've loved to see someone make their ram-air hoods functional with a TPI!!!
Old Mar 18, 2003 | 05:09 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
suncoast makes a box that will allow your ram air hood to be functional.. SD or MAF.
MAF is just as easy to make a cai, just minus about 6" of tubing for the MAF to be.
It's not rocket science.
Old Mar 18, 2003 | 06:04 PM
MdFormula350's Avatar
nice looking! great job..
Old Mar 18, 2003 | 07:25 PM
Adam62083's Avatar
I dont think the suncoast box will clear my ASCD hood. I dont want to pay 100 bucks to find out either
Old Mar 18, 2003 | 08:05 PM
devianb's Avatar
PVC is a good starting point and I think you will like the metal one much better. My first one was PVC until I switched to an aluminum piece.
TPI looks fantastic.:hail:
Old Mar 18, 2003 | 11:40 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
I'm starting to get the parts for my CAI....also out of PVC...the setup you have there is nice....its simple and effective. What size tubing did you use, and does the middle white piece have shaved off flanges? How did you make it all stay together all strong? Any resin, or did you just use those clamps that I see in the pictures? Also, I'm particularly intrested in the piece that goes into the intake...where did you get that piece? Maybe my eyes are tricking me but that looks custom made for that purpose specifically. Sorry for all the questions, I just dont want to screw this up and have my CAI falling off on the highway at 70mph. Any help would great. Thanks.
Old Mar 19, 2003 | 01:13 AM
Adam62083's Avatar
I got every piece from Home Depot.
Its all in the "Pipe" section. The white piece is simply a cut piece of 3" PVC pipe. The rest is rubber tubing found in the same section. All the pieces are hard and hold themselves together. No resin was needed.
Old Mar 19, 2003 | 06:57 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
Thanks for your help.....if the white piece was 3" in diameter, then i take it the black ends were 4" in diameter? or 3 1/2?
Old Mar 19, 2003 | 08:17 AM
smurfmobile's Avatar
guess I'll be the first to say that it looks cheezy, maybe it would be better if you had the TBI aka toilet bowl injection to match with the sewer piping , ya know , to complete the "look"
should have made that and get it to fit then remove it all in one piece and went to the nearest decent exhaust shop where they could have easily made it all out of metal for you using your potato gun intake as a template. would probably cost around $100 and it would look like it belongs on there :shrug:
Old Mar 19, 2003 | 08:31 AM
Steve89GTA's Avatar
wow, your K&N sticker is exactly where mine is!
strange though, my oil cap and PCV valve are the other way around..
Old Mar 19, 2003 | 12:42 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Originally posted by Steve89GTA
...strange though, my oil cap and PCV valve are the other way around..
Mine too. I guess they changed them after 89. I didnt even notice til you pointed it out
Brian
Old Mar 19, 2003 | 02:43 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
please, learn to read.
Adam, I'd love to see your new CAI...but my modem connect won't download the pics. It times out. Send me an email with a good pic so I can see it.
Old Mar 19, 2003 | 03:21 PM
Adam62083's Avatar
Hey its just 3" pipe, not a coupling. There werent any "ends"
Old Mar 19, 2003 | 04:00 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Adam...
I meant the flanges on the elbows....sorry I wasnt clear. Anyways, just to clarify, those hose clamps are all I need around the flanges on the black pieces to hold everything together? They'll be enough to hold the middle piece in? I have to figure something out with my MAF also...I have to work that in somehow...
Old Mar 19, 2003 | 04:33 PM
Adam62083's Avatar
Painted- Daytime shots.
For some reason it looks like its dull on one side. Im gonna go check that out after work. Maybe Ill put another coat of paint on it. could just be smudges from when i put it on though.
Phantom - The rubber pieces are pretty thick and hold their own shape, and the clamps will clamp everything together tight enough that it will just sit in place. Hope that helps
Old Mar 19, 2003 | 04:34 PM
Adam62083's Avatar
btw, where they connect after the throttlebody, there is a short piece of pvc under there that each side is clamping to. Thats how it stays hooked together seamless looking.
Old Mar 20, 2003 | 05:52 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you can find a tube like mine, it will fit your engine bay perfectly. My friend found it and put it on his 90 Formula 350.
Old Mar 20, 2003 | 12:01 PM
Redarrow1's Avatar
Car: 2001 Firehawk - SLP Longtubes
I was skeptical at first, but once I saw the pics I must say well done. But my real question is, has it made a noticable improvement?
Old Mar 20, 2003 | 12:19 PM
My86TransAm's Avatar
Originally posted by G92 IROC
Nice,
Gimme a couple months.....:rockon:
Old Mar 21, 2003 | 10:48 PM
89firechicken's Avatar
now with you air filter being right by the hot radiator picking up hot air from that and the motor how is it a cold air intake? from what i understand it would be a cold air intake if it was isolated from everything else putting the intake in it's own little world taking in the cold unheated air from the outside and pusing it through your filter that way. but it does look good just needs to be finished imo
Old Mar 22, 2003 | 05:21 PM
Adam62083's Avatar
What kind of air do you think it got when it was here:
Eventually I plan on making a shell around the filter so it pulls mostly from the fenderwell.
Old Mar 22, 2003 | 06:06 PM
bollox's Avatar
The piece that goes from the throttle body to the pvc pipe where did you get it? I've looked at home depot for a piece like that but havn't found one yet.
Old Mar 22, 2003 | 06:07 PM
bollox's Avatar
It looks good by the way, i'm going to put my battary in the back and have the pipe going through the tray.
Old Mar 22, 2003 | 07:03 PM
i never said that pulled cold air either i'm just saying that setup he made doesnt seem like a cai to me but yes it is a better idea than the pic you posted.
Old Apr 24, 2003 | 12:14 PM
formula91's Avatar
Car: 92 GTA
Engine: Yes
Transmission: Busted
Ressurecting the thread....
Been looking at these PVC cold air things for awhile. I'm interested in making something like this.
Been to Home Depot to look at PVC pipes and they only sell them in 10 foot lengths. Is this what you guys have bought and then just cut them to size? The 10 foot pipe is only about $9 or so but I'm not sure I could fit one in the car let alone cut it (a saw maybe?)
Would this be a legal thing to do in CA?
Guess I could always take it off for the stock stuff at testing time.
Thanks.
Old Apr 24, 2003 | 01:15 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Originally posted by formula91
....Would this be a legal thing to do in CA?
No. In Ca you have to have all the crap that is legal and you have to have the little stickers saying it is legal. A buddy of mine made one for his jap crap and got pulled over for racing, then they checked out the car and gave him another ticket for his home made CAI.
I just say take it off every two years when you have to smog it.
Brian
Old Apr 24, 2003 | 02:19 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
Accualy I went to Auto Zone and bought Muffler Extension pipe. needed to be cut a little bit with a hack saw but came out pretty nice after polishing. i think it was like $5-$6
Old Apr 24, 2003 | 02:21 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Re: Been to Home Depot to look at PVC pipes and they only sell them in 10 foot lengths. I
3" pipe? How long was it?
Brian
Old Apr 24, 2003 | 02:24 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
yea it was 3"
i cant remember the length of the top of my head but it will definatly be enough.
Old Apr 24, 2003 | 02:28 PM
formula91's Avatar
Car: 92 GTA
Engine: Yes
At Pep Boys yesterday I saw an 18" aluminum pipe that woulda been perfect. Except it was only 2 1/4" in diameter. That's the biggest they had.
Maybe I'll stop by Autozone in a bit.
Damn smog laws in CA are stupid. Who cares what the heck is under the hood if the exhaust is clean? Especially in this case, its just a plastic pipe! Dumb, dumb, dumb.
I want to make something like this for my 5.9L Durango but it wouldn't be as easy to put the stock stuff back on. On my GTA it would be a snap.
Old Apr 24, 2003 | 02:29 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
the one at Auto Zone is aluminum
Old Apr 24, 2003 | 02:31 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
Just curious
Does anyone here live in Ventura County ?
Old Apr 24, 2003 | 04:23 PM
Zepher's Avatar
Re: Just curious
I used to live in Ventura County in Oxnard / Port Hueneme.
That was back in 86 before I moved to Iceland.
Old Apr 24, 2003 | 04:25 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
ah dang, thats where i live right now, i thought you lived in Virginia right now tho ? oh and if ya dont recognize me i'm the same SydwayzTA, its just my other account got messed up or sumthing. the guy with the 86 t/a formula hood and all
Old Apr 24, 2003 | 04:27 PM
Zepher's Avatar
Ya, I live in VA now, been here since 91 or 92, can't remember.
Old Apr 24, 2003 | 05:16 PM
llvll4l2c91350's Avatar
this is my setup. 3" PVC with 90* elbows at the ends from home depot painted black. i didn't have to buy the whole section. i brought the factory setup with me and they cut it for me. looks good IMO.
Old Apr 24, 2003 | 05:22 PM
joshp14's Avatar
3" PVC with cone K&N
Old Apr 25, 2003 | 09:15 AM
formula91's Avatar
Car: 92 GTA
Engine: Yes
I asked Home Depot if they cut them to size and the guy said I'd have to buy the whole thing. I think your setup looks good too.
Anyway, I went to Autozone and found an 18" long, 3" diameter aluminum exhaust pipe. One end is slightly flared to about 3.5" but that should be ok.
Bought some aluminum polish too Now I just need a way to connect it to the throttle body.
Old Apr 25, 2003 | 09:58 AM
  #42
Car: 1986 Trans Am
Engine: 5.7L TPI
see told ya they had somthin. hehe it turns out looking good, i'll take pics of mine in a day or so
Old Apr 25, 2003 | 01:52 PM
  #43
Zepher's Avatar
Here is a cheap Dual CAI setup.
Old Apr 25, 2003 | 01:54 PM
  #44
Car: 1986 Trans Am
Engine: 5.7L TPI
quite interesting there Zepher, not sure it i'd put it in my car but does seem effective
Old Apr 25, 2003 | 02:01 PM
  #45
Zepher's Avatar
It's not going on my car either. It was a concept I had back when I was doing the TPI swap. I coudn't afford the $300 SLP Dual CAI at the time so I was going to use this. Then I found a slightly used SLP unit and put that on my car.
I love this pic of my old setup,
  #46
formula91's Avatar
Car: 92 GTA
Engine: Yes
Have you done yours yet with the Autozone tube? How did you join the metal tube to the throttle body?
Pics would be nice.
My car is in storage so I'm gonna take my time. I'll probably just polish the tube next week.
Old Apr 25, 2003 | 02:03 PM
  #47
Zepher's Avatar
Oh, here is that huge pipe on my engine,
Old Apr 25, 2003 | 02:10 PM
  #48
Car: 1986 Trans Am
Engine: 5.7L TPI
formula91
yeah i did my cai already with the auto zone pipe, had to cut off about 3 inches if i remember correctly, with a hack saw, used the stock angle connector that came on most later thirdgen tpi formulas/ trans ams, then a 3" 90degree angle rubber hose and connected that to my MAF Sensor then to my filter
Old Apr 25, 2003 | 02:27 PM
  #49
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I made a CAI too
I used pipes from http://www.westcoastbending.com that I got for about $12 each shipped (purchased mild steel pipes in bulk for possible future products to sell). Then I used silicone adapters from http://www.bakerprecision.com to complete the installation. If I were doing it again (and I will), I'd be placing the MAF closer to the TB to get it away from the coolant lines.
Old May 5, 2003 | 12:50 AM
  #50
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Its a 4" to 3" piece its there if you look
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
dusterbd
Sep 29, 2015 08:40 AM
