What do you think of my Idea helP!!!
Old Mar 18, 2003 | 05:57 PM
firebird13's Avatar
COLOR=red]ok guys i was thinking..Im wanting to get the gta front end and get like 91 rs gfx for the side. How hard would it be to change my stock front end and put on side skirts..give me all the pictures you can!! instructions and all how to put this stuff on plz guys help me out this is problly going to be my spring project!![/COLOR]
Old Mar 18, 2003 | 06:15 PM
NEEDforSPEED's Avatar
i think, im sure its been done!... iv seen it on this board!... as for being hard i dont think it would be, but im sure its going to take some time
Old Mar 19, 2003 | 02:42 PM
firebird13's Avatar
guess nobodys got anything to help me??
Old Mar 19, 2003 | 03:16 PM
Drakar's Avatar
I haven;t done it myself but I believe the largest problem with the GFX is the bolts holes are different and will need to be added/filled accordingly.
Also the front end should be asimple swap with a few bolts off and put the new one on and bolt it up again.
Old Mar 19, 2003 | 03:50 PM
firebird13's Avatar
Thxs anybody els got any 2 cents i can get??
Old Mar 19, 2003 | 04:03 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
zepher put the 91-92 camaro gfx on his 86 bird, might want to PM him he could prob help you out a little
Old Mar 19, 2003 | 04:13 PM
firebird13's Avatar
k
Old Mar 19, 2003 | 05:27 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here are some shots of the body with the holes for the door molding filled in,
The rocker panel pretty much bolted up to the stock holes under the door. The front and rear of the rocker panels aren't bolted up, if you notice the holes next to fender vent, the 91-92 gfx uses holes that are lower for the bracket. Those need to be filled as well if you have 85-90 graound effects.
The door molding needs 3 holes/door drilled and then the old 3 holes filled.
Here is a shot of the gfx bolted on before we filled in the holes on the door.
you can see one hole in the door,
This is how the car sits now,
Old Mar 19, 2003 | 05:44 PM
firebird13's Avatar
hey but i dont have any gfx..my cars 87 firebird..nothing but car no gfx.. how hard would it be to put them on with nothing??
Old Mar 19, 2003 | 05:45 PM
Zepher's Avatar
Should be easy. Just tape the rocker on the car and drill all the holes. Door isn't too hard either.
Hardest thing for me was finding the door pieces. Took me 6 months to find a used set. GM wants $120/molding, $40/bracket.
I got my door pieces for $120, and that included the brackets.
I got my rocker panels for $35.
Old Mar 19, 2003 | 05:47 PM
firebird13's Avatar
Ok, you got aol? or aim?? ok if not let me get this strait u just drill them on..and then like bolt them on..so what happens when watter gets up in there? your car get bad case of cancer right??
Old Mar 19, 2003 | 11:48 PM
Zepher's Avatar
Yep, drill the holes and bolt them on. you can use silicone over the nuts to seal it.
I have AIM but I don't get on much.
Old Mar 20, 2003 | 08:04 AM
firebird13's Avatar
K sounds easy thanks!
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
