4th gen rears
Old Mar 25, 2003 | 04:57 PM
duke_mushroom's Avatar
4th gen rears
Hey, how do 4th gen rears look on 3rd gen cars? I'm going to do this once I have my motor and tranny swapped, but I want to see how it looks first.
Old Mar 25, 2003 | 05:39 PM
5SIZ's Avatar
Car: 1987 IROC-Z
look like a normal rear end, except the rear tires stick out a bit more a couple of inches I think it was. you also do not need spacers for the rear to adapt the 3rd gen rims onto it.
Old Mar 25, 2003 | 07:36 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I did it, its not too bad heres pics.
Old Mar 25, 2003 | 07:37 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
Old Mar 25, 2003 | 07:39 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
anothert
Old Mar 25, 2003 | 07:40 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
one more for good measure.
Old Mar 25, 2003 | 08:11 PM
Matt's Avatar
Just a simple question but what are the benifits of the 4th gen rear?
Old Mar 25, 2003 | 08:17 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
nothing really.. they are just newer and usually have higher gears.
From what I read, they are just as strong as the 10 bolt found in most thirdgens.
Old Mar 25, 2003 | 08:33 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
You forgot that with the 4th gen rear you have discs on the rear unless you got a cheap 4th rear lol
Old Mar 25, 2003 | 09:09 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I got mine for 200.00 with 30,000 miles on it. They have bigger disc brakes than the 3rd gens, mine has 3.42 gears as opposed to my old 2.73's and I dont need spacers when I get the money up for my c-5 wheels.
Old Mar 25, 2003 | 09:17 PM
dpav's Avatar
What about the brake lines / ebrake...and don't some fourth gens have ABS? How does all of that factor in...and is it really as easy as the tech article makes it to be?
Old Mar 25, 2003 | 10:36 PM
Firebird355's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
the rear end in my 89 formula had 3.42s and disk brakes, i have that car for parts and that rear is goin in my 88, the 88 orig had a 2.8 in it..
Old Mar 26, 2003 | 11:42 AM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I am not sure about the abs... My brake lines bolted right up. As far as the 4th gen e-brake lines, I had to shoten the outer housing about 6 inches and grind a flat spot on the ball on the end of the cable so it would fit into the splitter. Other than that everything bolted right in like it was made for the car.
Old Mar 26, 2003 | 01:37 PM
LT1guy's Avatar
Car: 1987 Trans Am
Nice job, 91Dub...I can tell you spent some time detailing everything. The ABS on 4th gen rears isn't an issue; the brakes work fine without it.
BTW I think this the first car I have seen with a 4th gen rear and stock wheels; I thought they would stick out too far, but it looks good. I'll probably do the same on my 87 til I save up for some nice rims.
Old Mar 26, 2003 | 08:08 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
Yeah they dotn stick out too far... I still want to get some wheels with the correct back spacing so everything looks flush again.
Old Mar 30, 2003 | 11:22 AM
That looks good. When people said they stick out, I kept getting pictures of those lowrider camaros with the gold spoked wheels. But that doesn't look bad at all. BTW, excellent job on the detailing 91dub.
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
