"91/92 formula nose ..same as base???"
Old Apr 9, 2003 | 12:30 AM
devianb's Avatar
I and a fellow member are debating weather or not the 91-92 Formula noses are the same as the base models 91-92 noses for Firebirds.
I say, and know that they are exactly the same. Anyone agree with me?
Old Apr 9, 2003 | 01:34 AM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
It depends, you could get the base firebird with or without the appearance package, in which case they'd be different. My base model bird has the appearance package, and the nose is different than that of the formies.
Old Apr 9, 2003 | 02:07 AM
Adam62083's Avatar
exactly.
Old Apr 9, 2003 | 08:37 AM
DaGoat's Avatar
Base models have elongated slits on the front to accomadate the foglights, where as the formula's have a black plastic cover extending into that area. I don't have any pictures to explain, but I'm sure if you look closely you'd see what I'm talking about.
Old Apr 9, 2003 | 08:54 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
What he said
Old Apr 9, 2003 | 12:46 PM
devianb's Avatar
Ok then, so is this an accurate statement then,
The nose with no ground effects will be categorized as a Formula nose and the nose with ground effects will be classified as a TA nose
Old Apr 9, 2003 | 12:48 PM
DaGoat's Avatar
yes, it is accurate, but you could take the ground effects off of a TA nose and it still wouldn't be the same as a formula nose.
Old Apr 9, 2003 | 12:55 PM
DaGoat's Avatar
Formula
Firebird
Old Apr 9, 2003 | 07:43 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Do you see the difference now?
Hey devian b
the base nose is really close to the T/A nose on 91/92s
the only different is the Formula nose ¡
Old Apr 9, 2003 | 07:58 PM
91FIREBIRDGT's Avatar
Car: 1991 Firebird
Engine: 3.1LV6
actually i've seen base firebirds without the foglights and have the formula front. base firebirds with out the W68 appearance package got the formula style front while the ones with the W68 got the T/A style front. The GTA's got the T/A style front but with a badge inplace where the bird goes.
Old Apr 9, 2003 | 09:20 PM
Keith27's Avatar
Hey thats my Formula.. Thanks for showing it DaGoat!
And yes the standard 91-92 Firebird and the 91-92 Formula noses are the same.
Peace
Old Apr 9, 2003 | 10:11 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
On the 91-92 TA nose, you CAN'T take off the ground effects. They are molded into the nose. Without learning the codes for the option packages etc. etc. basically all you need to know is this:
There are two styles of 91-92 Firebird front bumper covers:
(1) Ground effects style
(2) Non- Ground effects style
All Formulas had non-ground effects style. All T/A's and GTA's had ground effects style. The base Firebird could be had either way.
Old Apr 10, 2003 | 08:31 AM
DaGoat's Avatar
Originally posted by Keith27
[B]Hey thats my Formula.. Thanks for showing it DaGoat!
Kick *** ride you got there man. :hail:
Old Apr 12, 2003 | 02:27 PM
Keith27's Avatar
Thanks man.....
I still have a long ways to go...
BOOT77
Oct 17, 2015 12:09 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
mrestrictrplate
Sep 21, 2015 11:24 AM
okfoz
Sep 17, 2015 10:30 AM
Formula_88AE
Sep 3, 2015 01:47 PM
