what does everyone use for this??
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
what does everyone use to degrease their engine? brand names...etc. and does it affect the wiring or the throttle body in my case... list your procedure too.... my engine is gettin to be really disgusting and i wanna clean it up..
Car: 88 IROC Convertible
Transmission: Raptor 700
soap, water, and a toothbrush
theres a bunch of other products that i use to maintain the engine bay like eagle one New finish (can't remember the name of it, comes in a small tin can and has a cloth like thing in it) works pretty good to maintain the aluminum parts. Soap and water for pretty much everything else
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Originally posted by bad84z
gunk foamy engine brite. I have also used simple green, just a little more scrubbing.
If your engine is really greasy do it at the local carwash or your driveway will end up looking like your engine once did.
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Power clean...I think...Purple power...very strong...keep off polished and ceramic coated products...Spray on hose off...then tooth brush for the hard to get off stuff. The spray on degreaser just gets you started...to really get it clean...toothbrush with degreaser and rags & water...
Car: currently thirdgenless!!!
If the engine and engine bay are real bad, I would use gunk or some other product like that. For follow up cleanings about once a month or so, I use Simple Green. I will not hurt paint and it is bio-degradable. Won't hurt plants or animals.
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
I would put one over your altenator, your distributer cap, anything you know it would cause problems on. I use windshield washer tubing connected to the outside facet. That way it gives you a tiny stream of water to work with instead of just soaking it with a big hose. Just go to walmart in the lawn and garden, and you can get the adapter to fit your facet. WOrks for me, havn't hurt anything yet.
Engine: 305 tbi=LO3
Transmission: Automatic
i use that gunk stuff then i use kerosene. then i cover the distributer and alternator and then spray down then engine after covering it with gunk and kerosene.
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Originally posted by DJP87Z28
I never use that junk because I never let my engine ge that dirty.
