Lexan T-Top Question
Old Apr 29, 2003 | 12:06 AM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
I have lexan T's and they look really bad, scraches and what looks like waterspots or something. Any way is there anyway to recondition them or polish them????
Old Apr 29, 2003 | 12:07 AM
joshp14's Avatar
I believe Eastwood sells a Glass polishing kit. Are the lexans glass?
Old Apr 29, 2003 | 12:16 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Laxan is like Plexiglas. It is made out of plastic.
My stock glass t-tops were replaced by factory recall with laxan ones before I bought the car. They have tons of little crack lines and stuff in them. They are a lot lighter and darker then the glass ones though.
Old Apr 29, 2003 | 01:21 AM
joshp14's Avatar
I would try some plastic buffing compound from Eastwood Company. I polished my tail lights and it got rid of ALL of the scuffs/scratches. You can see my tech article HERE and scroll halfway down.
Old Apr 29, 2003 | 01:29 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
That’s not going to work because a lot of the cracks are actually in the T-tops so buffing the surface won't be able to get to them. It will help to get some scratches off the surface but a majority of the cracks are within the laxan.
Old Apr 29, 2003 | 01:35 AM
joshp14's Avatar
i dont know if you will be able to get the cracks out or not...
Old Apr 30, 2003 | 07:51 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
Hey i went to the eastwood website but could not find plastic buffing compound. Do any of you know a product # or a direct link. Thanks!!
Old Apr 30, 2003 | 08:16 PM
joshp14's Avatar
Can't give you a direct link cuz the address to that site doesnt change no matter where you are at on their site! But I can tell you that the stock # is 13138.
Old Apr 30, 2003 | 08:55 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
There is a Gm Technical Service Bulletin about the lexan T-Top coating deteriorating and giving it a blotchy, peeling sort of look. The GM approved fix: replace them with 91-prior T-Tops. My 92 Z28 has this exact same problem and I've tried everything to no avail. If you want a copy of the TSB I can get it for you. As far as the scratching goes, you can try to get them out with an aggresive polish. But with that horrible blotchiness on the coating, whats the use?
Old Apr 30, 2003 | 09:13 PM
Belker's Avatar
I have lexan t-tops that look like crap when you look THROUGH them but found a way to generally make them look alot better when you're just looking at the car. I just polish them with the same polish that I use on my paint. For the paint I use a cleaner, then a polish, then a wax. For the t-tops I just use the polish. It removes buildup, waterspots, and fine scratches. They look way better after this done.
Old May 4, 2003 | 03:55 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
Has anyone actually used this plastic buffing compound? Are you sure it wouldn't work? If anyone has tried....... post man.
Old May 4, 2003 | 04:13 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
No matter what you do you are not going to get the cracks out of the laxan when looking though them from the inside of the car. Plastic buffing compound and a buffing wheel should make them look better from the outside. It won’t hurt to try it.
Old May 4, 2003 | 08:23 PM
25THRSS's Avatar
Has anyone tried sanding them then polishing them out?
Old May 5, 2003 | 08:49 PM
Belker's Avatar
I'm telling you guys, try something like McGuires Paint Polish. This will make a big difference. It's not worth the effort to not try this and instead try something harder. At very least, after doing this, you'll easily be able to tell what is IN the plastic and what was just on the surface.
Old May 5, 2003 | 09:28 PM
25THRSS's Avatar
I have a couple pretty deep scratches that I dont think just polishing will remove. Can I sand them down and then buff them out? Anyone done this before?
Old May 5, 2003 | 09:39 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
Do a search, this has been brought up before.
Yes, you DO sand.
I used Blue Magik (?) plastic and plexiglass polish. You can find it at most automotive stores and probably Wal-Mart. It's only a few bucks and it works. My t-tops (Well, one of them, I havn't done the other one yet) look like glass now.
It wont get the little cracks out, but it will really make them look alot better, trust me!
Old May 5, 2003 | 09:46 PM
25THRSS's Avatar
What do you mean, "yes, you do sand?" Are you saying it wont hurt it if I do sand them? Also, should i dry sand or wet sand them? Thanks
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
t-top89
Exterior Parts for Sale
Aug 21, 2015 09:52 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
redmaroz
Aug 16, 2015 11:40 PM
