Trouble with hood opening
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey on my dads 91 GTA and 90 Formula, when you pull the hood latch, the hood does not pop up, you kinda need to press on the hood and then it will unlatch. This does not happen on my 82, so I'm wondering what causes this.
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I just replaced my hood latch. Its like $26 from the chevy dealer. The old ones get worn out and filled up with crud. Slap a new one on in like 3 minutes and you're golden.
Car: 1987 GTA
Transmission: 4L60e
I second that loobing. Take some bearing grease or goop or whatever and just coat the apparatus. This is much easier and cheaper than replacin anything.....has worked on 3 of our cars.
Car: 89 RS
Transmission: TH350
First off, spray some litihium grease on there and see if that helps. If not, try moving the whole latch assembly down abot an 1/8th of an inch.
Also check the spring, and the cable for slack.
Hotrodboba400
Sep 2, 2015 07:28 PM
