Front bumper and ground effects
Old May 26, 2003 | 03:22 PM
SYPHON556's Avatar
Car: 87 Camaro Convertible
Engine: 305 LG4
Alright, I haven't posted in like a year but I'm back with more questions. I am going to get a new/used front bumper for my 87 Camaro. What I want to get though is one that has the ground effects. I also noticed that the grill on the Camaro's w/ ground effects actually goes down into the ground effects themselves. I am assuming I will have to get a different bumper than the one I had before, right? I also do not have the ground effects on the fenders too.
What I need to know is: what pieces do I need? What are all these pieces called (I'm bad with termanology)? About how much all all the parts cost?
Thanks!
Old May 26, 2003 | 05:49 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
You need the front bumper cover and front spoiler from a 91-92 camaro.
Old May 26, 2003 | 07:48 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
hey im planning on putting a 85-90 front bumper cover on my 84..is it somewhat of a direct swap or is there some fab work necessary? ive tried to ask this so many times and never got a clear answer..and ive searched and found nothing about the installation itself.
Old May 26, 2003 | 08:03 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
You'll have to get a 85-92 Z28,IROC, 88-92 RS, 88 SC camaro front nose. A 85-90 Front Spoiler or a 91-92 style. Door gfx, rocker panel gfx, rear quarter panel gfx, and a 85-90 Rear bumper or 91-92 bumper. I perfer the 91-92 style gfx the most, What you will need to do is drill holes for the front spoiler to bolt onto the bottom of the fender, the door gfx, rocker panel gfx, and rear quarter gfx.
Luckly the front bumper and rear bumper will bolt on with no modifications what so ever. This project will not be easy, one word of advise is to make cardboard templates of the hole locations to make the whole project much eaiser.
I did this same thing to my 85 SC over a year ago, you can see pics here:
www.cardomain.com/id/85camaromike
Old May 26, 2003 | 08:07 PM
Car: 85 Camaro SC
Engine: V6
The bumper will bold right up to the fenders but you'll need to change the bumper impact abosrber so it will bolt up properly, the honeycomb thing.
Old May 26, 2003 | 11:34 PM
SYPHON556's Avatar
Engine: 305 LG4
I just need to have the front bumper/fender done. I'm sure I wont use the door gfx, the rear quarter panel gfx, nor the rear bumper.
What exactly is a rocker gfx though? Does the front spoiler go all around to the fenders too? And does the front spoiler year have to match up with the front nose year (like can I mix an 88 nose with a 91 spoiler)?
Thanks again!
Old May 27, 2003 | 12:20 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I just shaved the impact plastic underneath with a "saws-all" when I clone my old 84 to a 91-92 Z28 ...
Old May 27, 2003 | 03:54 PM
SYPHON556's Avatar
Engine: 305 LG4
Is a lower air dam the same thing as the front ground effect panel?
Old May 27, 2003 | 04:07 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
could always just make your own body kit like me
Old May 27, 2003 | 04:23 PM
Car: 85 Camaro SC
Engine: V6
The bumpers that use the ground effects can be used with either the 85-90 or 91-92 front spoiler. The 82-84 front bumper is way different and so is the spoiler. So you can get any kind of front bumper that uses the ground effects as long as its a 85-92 bumper that uses a spoiler, any Z28, Iroc, RS, and a 88 Sport Coupe use that bumper. I'll attach a pic of my car, the front bumper spoiler wraps around to the bottom of the front fender, 3 holes need to be drilled to allow the gfx to be bolted on the side and not flop around in the wind. The rocker panel gfx are whats on the side of the car, The middle of the car.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
mikey8494
Aug 22, 2015 07:57 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
92firebirdchris
Aug 14, 2015 11:56 AM
