Polished Plenum
Old May 29, 2003 | 12:45 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Polished Plenum
Yes now i have done it. I polished that plenum really good and it looks great. Im going to get pictures tomorow so you have to wait. 3 hours of hard work.
Everybody post your pic of your polished plenum, would be fun to see who got the best finish.
Old May 29, 2003 | 02:04 PM
Thirdgen86TA's Avatar
Only 3 hours? It took me a little more
Did you do it all by hand?
Old May 29, 2003 | 03:29 PM
bigals87z28's Avatar
Car: Check The Sig
3 hrs? did you just do the top? How did you go about doing it? did you hand sand it or use power tools? compounds or sanding? Im up to around 3 hrs total with polishing mine and im at 400 dry. I think im gunna start with mothers and polish with my car buffer. Sound like a good idea? After mothers, what do you guys recomend to finish it off with?
Old May 29, 2003 | 03:30 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
i did my plenum in about 2 hours
i used a palm sander and only did the top, looks pretty good.
Old May 29, 2003 | 03:32 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Took me an hour and a half to do mine, tonight i'll do the intake and polishing the lines in the plenum that will be fun
I need a new digi camera that takes better pics, my hp215 sucks and so did my painting. Tonight i'll polish the lines since my new wheels came in
Old May 29, 2003 | 04:03 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I have about 4 hours in mine....just did the top....
Old May 29, 2003 | 04:47 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I have probably around 4-5 hours into mine. I polished the top and sanded the sides smooth.
The next time I take it off, I'm gonna polish the whole thing.
Old May 29, 2003 | 07:30 PM
Dan88IrocZ's Avatar
About 3 hours...
Just the top also...
Old May 29, 2003 | 08:34 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
heres mine.....
Old May 29, 2003 | 10:57 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
I've got probably 2 and a half hours into mine between the grinding down of the front part (it was a pre 90 plenum) sanding the casting down, polishing the top, and powdercoating the sides and underside black.
Old May 30, 2003 | 03:23 AM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Is there gaskets in there on yalls like runners/gasket/pln?
Cause someone uses a whole tube of gasket glue and no gasket and i cant get mine off to finish it...Any ideas?
Old May 30, 2003 | 06:29 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yeah i only did the top , i will do the rest this winter.
I wetsanded it by hand using 80, 120,240,400,600,800,1000,1200 and 2000 paper. After that i used a chromepolish and a polish machine.
Old May 30, 2003 | 09:53 AM
use a scrapper dude, might take a while but .... i cut myself like 100 times doing it
Old May 30, 2003 | 10:40 AM
Adam62083's Avatar
Old May 30, 2003 | 10:49 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Those look bada$$ !! But beleive it or not, the unpolished plenums/runners disapate heat better, hence keeping a slightly denser air charge. Just a thought!
Old May 30, 2003 | 11:54 AM
MdFormula350's Avatar
hmm interesting, never thought of that before.
Old May 30, 2003 | 04:59 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Old May 30, 2003 | 05:02 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
I like this cap I didnt do the polishing though. Looks good on the car.
Old May 30, 2003 | 08:36 PM
87GTA Runner's Avatar
Car: 87 GTA
5-6 hours
Old May 30, 2003 | 08:46 PM
heres 2 more...I got my TB back from Mike.....whatcha think? I just put it all together to keep up with all of it till I get the manifolds off, Im putting headers in...
Old May 30, 2003 | 08:47 PM
other
Old May 31, 2003 | 10:42 PM
Car: 85 Camaro SC
Engine: V6
As promised one polished intake I spent 8 1/2 hours polishing it but it would have taken about 5. I wasnt happy how it was polishing out so I re hand worked the intake and repolished.
Old Jun 1, 2003 | 11:07 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Very nice...I was looking at your price sheet. Your prices are very reasonable. For the amount of work required to get them to look that good.
Old Jun 4, 2003 | 02:44 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Finally i got pictures. Im still waiting for the alu dist cover i bought from Thirdgenresource.
Old Jun 4, 2003 | 02:46 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
oh why not one more picture.
Old Jun 4, 2003 | 02:49 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yes im going to get large tube runners and then i will polish them.
Old Jun 4, 2003 | 04:03 PM
Car: 85 Camaro SC
Engine: V6
Not too bad, hand polishing? While still bolted on I dont see how you guys can do it like that.
Good story behind this pic, I made the program, set the cnc up at college, and now I'm polishing all 70 of them so they can be givin out as trophies. the only thing I hate is the person who was running the machine let the 1/4 end mill dull and didnt replace it, so the sides are pretty gouged/burred up badly There I went and wasted all that time getting the spindle speeds and feed rates perfect for a superb finish, Down the drain
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
