Pics of DropZone Lowering Springs.....clearance
Here are the pictures showing how much the DropZone lowering springs have lowered my car......
Remember that the front has had weight savings done....
Fiberglass Hood - 50 lbs
Plastic Headlights - ???? (removed front headlight bar, and the 4 glass headlights)
Here is the clearance of the Air Dam....
Sam....Your car officially owns me
Your car is very close to what I want my car to be @ the end of the summer. Can you please list the price you paid for the 17" Neeper Synchro's & the apache wing? Thanks a lot dude
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i think if u take out the spring isolators on the top of the rear spring itll drop it down to make the rear even. just put some garden house around the coil till its a complete circle.
Car: 82 camaro SC
Originally posted by devianb
Looks good. Did you have to get a camber correction kit?
Don't worry about the air dam, it will trim itself.
Car: 1988 GTA
Engine: 5.7L/L98
Hey "82camaro" here I was starting to think I was the only one with a Ravin exhaust. I love the sound of mine! Even sounded better once I put the Catco in. Nice tone without being abrasive!
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
how much of a drop is that on your car i have an eibach 2 inch drop i am putting on my car as soon as i get it back from the body shop
The advertised drop is rarely achieved.....If it says 2 inches you will probally get 1.25 - 1.75 of a drop
Well if you get drop spindles like I plan on getting, the drop is garaunteed close to 2" although since the rear is lowered with springs, that could vary too.
The amount of drop is also determined by the weight of the car. Thirdgens can range from 3000 lbs to 3800lbs and obviously the heavier car will experience the lower drop.
Car: 2002 Formula Firebird
Transmission: 4l60e
That isn't bad at all. That isnt really that low. Mine is ALMOST that low with the stock springs sagging. I think I will get a set of the dropzones now.
Where did you get them and how much? They are all over ebay right now for 89$ but none for our cars are listed.
morrow
Jan 13, 2024 12:29 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
Night rider327
Sep 2, 2015 04:17 AM
