Anyone know where i can get some 15" iroc rims and will they fit?
Old Jul 13, 2003 | 03:20 PM
89ProchargedROC's Avatar
Someone please let me know if i am right:
the 15" versions of the 88-90 iroc rims are 1" narrower (7" wide versus 8" wide) and i was told that they wont fit rearends with the PBR rear calipers
but
i'm assuming that they will fit if you do a little grinding on the calipers correct?
Also, does anyone know where i can get some or if anyone would want to trade for a set of 16" IROC rims straight up or possibly work something out?
Old Jul 13, 2003 | 06:26 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Theres been an 88-90 15" set on ebay for a month or so looked like they were in good shape. Not sure if they sold the last time they were up for auction. The minimum bid was around 400.00, They are 15x7.
I think the place that had them for sale was called Trans am creations. They are pretty well known in Florida. They sale used and new fbody parts.
I just checked they are still for sale the auction ends in about 5 minutes though.
Mike
Old Jul 14, 2003 | 12:16 AM
i did see that ebay auction thank you but i am not paying $400 for everyday IROC rims and they did not want to trade me for my 16" rims either
Old Jul 14, 2003 | 08:21 AM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
first off... yeah I am pretty sure the 15" irocs would hit the calipers. I would advise that you wouldn't grind the caliper, you would more than likely need to do more than just a "little" and it would probably affect the durability of the caliper!
but why would you want to go from 16" Irocs to 15"?
Old Jul 14, 2003 | 11:52 AM
Grinding the caliper is common practice and i'm going to have to more than likely grind them for my Bogart rims anyhow
the reason why i want the 15" iroc rims is so i can put a larger size drag radial tire on them and still keep my car stock appearing
i can only put a 245 nitto or 255 BFG drag radial on my 16" wheel which honestly would just be a waste of money with my money. I need 15" rims so i can throw on a 275/50/15 on them
thanks
Old Jul 14, 2003 | 03:19 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
first off they never made 15" iroc wheels, maybe ur thinking of older Z28s, and no the 15" rims dont have the clearance for the big pbr calipers
Old Jul 14, 2003 | 03:26 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Yes they did. This was taken from another thread...
In 89 they were a mini 16x8 Iroc wheel. Sized down to 15x7, but looked the same as the 16x8's.
Old Jul 15, 2003 | 12:29 AM
i'm sorry, but dont be so sarcastic. they DID make 15" IROC rims...do some research. 16" IROC rims weren't always a standard item
True, 15" rim dont have clearance for the PBR calipers but you can grind down the fins to make them fit. Not a big issue
Old Jul 15, 2003 | 01:43 AM
CrazyHawaiian's Avatar
Car: too many ...
Well I dont know anything about a 15" IROC wheel, but I do know that a 15" RS wheel (15x7) will fit over the rear PBR disc setup found on IROC's, Z28's, 1LE's, and B4C's (its all the same stuff). They will also fit over 1LE front brakes. I was somewhat supprised to hear this, but it came from AndyZ28 and I trust what he says (he knows his stuff). he also said he has pictures of the 15's on a 1LE spec car on his 1LE CD. Check the end of the post here.
Old Jul 15, 2003 | 02:09 AM
MetKiss316's Avatar
Starting in 89 and going through the 1990, IROCs came standard with the 15x7 inch IROC wheel. The 16x8 one, which most have, was an option.
Old Jul 15, 2003 | 01:47 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
my 88' Iroc came with the 15x7's the research i did sais that in 88 was the first year to start the 15" wheels
Old Jul 15, 2003 | 05:25 PM
82camaro's Avatar
Car: 82 camaro SC
Yep, 88 had 15's as well. They looked different though. They were the 'normal' 15x7 5 spoke aluminum wheels, painted all silver or all gold with a different center-cap. I have a set on my 91 Jimmy.
I have also heard they will clear the better brakes. I can't imagine 275's on a 7 inch wide wheel is going to hook really good--needs to be wider IMO.
Old Jul 15, 2003 | 11:34 PM
with the amount of torque my motor makes it will be better than a 245 on a 16" wheel
that is what im trying to get after, i need the bigger sidewall to help absorb some shock from the launch
Old Jul 16, 2003 | 11:13 PM
Car: 1989 RS Camaro
This is straight from the camaro history from this site:
"The 16 inch wheels that had been standard equipment on the IROC were restyled and now became an extra cost option for the IROC. The standard IROC wheel was the old 15x7 inch aluminum 5 spoke Z28 wheel and this wheel was also now standard on the Sport Coupe."
Old Jul 17, 2003 | 10:26 AM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
89' RS/blue
Dude..They did have 15" Iroc wheels,shall I show you a picture.
Old Jul 17, 2003 | 10:33 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
91Zman
91Zman is right. Standard wheel for 88-90 IROCs.
Old Jul 17, 2003 | 10:35 AM
91Zman's Avatar
Car: 1991 Z28
A little past half way down there's a pic of it next to a 16" wheel.http://www.iroczone.com/techartspottersguide.html#88
Old Jul 17, 2003 | 02:11 PM
NO OFFENSE TO ANYONE HERE BUT IF YOU DONT HAVE ANYTHING TO ADD CONSTRUCTIVELY TO THIS THREAD, GO ARGUE SOMEWHERE ELSE
if you dont know anyone who has some 15" IROC rims for sale, please dont post here. We've already figured out they will fit so i just need to find them
Old Jul 17, 2003 | 11:30 PM
Car: 1989 RS Camaro
yea could u show me a pic, ive never seen them
Old Jul 17, 2003 | 11:34 PM
91Zman's Avatar
Car: 1991 Z28
check my previous post.:lala:
Old Jul 18, 2003 | 01:34 AM
MetKiss316's Avatar
It came with 15s, but not the 15 inch version of the 16inch wheel.
15" Aluminum Wheel
1988 - Standard
15" Aluminum IROC wheel
1989 - Standard
1990 - Standard
http://www.iroczone.com/techartspott...de.html#wheels
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
