degreasing question
Old Jul 16, 2003 | 02:56 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
degreasing question
ok i degreased my engine bay today and i covered the battery and the distributer. ok, i got the distributer a little wet. not like a hose on it but a little when i took the bag off and the water in it spilled on it (maybe a little when i sprayed too). Is it ok if that happens? or what should i start it?
Old Jul 16, 2003 | 05:19 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
damn i'm in deep ****...... after i degreased it and let it dry down well i decided to see if it started.... started up perfect then 15 seconds later it was idleing at 450rpm and acting like it only worked on 3 cylenders so i floored it and it idles nice but the service engine soon was now on and wouldn't go away. wtf do i do?
Old Jul 16, 2003 | 05:52 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
check to see what code got set off and go from there.
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
how do i tell?
Old Jul 16, 2003 | 05:58 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
From the tech articles:
If your car does not have the 12 pin DLC connector, you may not be able to manually "flash" your trouble codes. The language "may be possible" appears to suggest that this method should work with most, if not all, 12 pin DLC equipped cars.
THE CONNECTOR
| 1 2 3 4 5 6 |
| 7 8 9 10 11 12 |
DISPLAYING THE TROUBLE CODES
Run a wire/hairpin from Pin 6 to Pin 12 with the ignition off (although on later cars it should be from Pin 5 to Pin 6), then turning the ignition to the on position without starting the engine will flash the "Service Engine Soon" light in the following sequence: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause Following this "12" code repeating three times will come any trouble codes stored, flashing each of them three times. If you do not see the "12" flash three times, your diagnostic circuit is defective.
Some vehicles will display stored trouble codes, then "12" again, followed by energizing "most system controlled relays." The fuel pump relay will not energize. The idle air control valve will fully extend to enable checking minimum idle speed.
CLEARING THE TROUBLE CODES
Turn the keyswitch to the off position. To clear any trouble codes, disconnect the power feed for 30 seconds. If this is done at the battery, and your car stereo is equipped and programmed with a four digit pin code, you may have to re-enter that as well to use your stereo again. A better place to remove power is at the fuse.
TROUBLE CODES
12. No reference pulses to Electronic Control Module (ECM).
13. Oxygen sensor signal stays lean during warm engine cruise
14. High temperature indicated at engine coolant temp. sensor
15. Low temperature indicated at engine coolant temp. sensor
16. High battery voltage OR
Direct inition system open or shorted to ground
17. RPM signal problem
18-20. N/A
21. High voltage at throttle positon sensor
22. Low voltage at throttle positon sensor OR
Fuel cutoff relay circuit open or shorted to ground
23. Low temperature at manifold air temperature sensor OR
Throttle position sensor error
24. Circuit fault in vehicle speed sensor
25. High temperature at manifold air temperature sensor OR
Vacuum switching valve circuit open or shorted to ground OR
High voltage at ATS sensor
26. Fault in quad driver module
27. Fault in 2nd gear switch
28. Fault in 3rd gear switch
29. Fault in 4th gear switch
30. N/A
31. Low voltage at manifold absolute pressure sensor OR
Fuel injector OR
Park or neutral switch OR
CAM diagnostic OR
Governor malfunction OR
Wastegate overboost OR
Wastegate eletrical signal open or shorted to ground
32. Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch OR
Fault in electronic vacuum regulator valve
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
35. Idle speed can not be set to desired RPM
36. Burn off at mass air flow sensor OR
Problem in transmission shift OR
Fault in direct ignition system OR
Missing pulses in electronic spark timing signal
37. N/A
38. Fault in torque converter clutch brake switch
39. Fault in torque converter clutch circuit
40. N/A
41. Fault at cam sensor OR
Cylinder select error OR
Tach input error
42. Fault at electronic spark timing circuit OR
Fault at direct ignition system OR
Fault at fuel cutoff relay circuit
43. Low voltage at electronic spark timing circuit
44. Oxygen sensor lean
45. Oxygen sensor rich
46. Fault at vehicle anti-theft sytem OR
Fault at power steering switch
47. Problem at Electronic Control Module (ECM)
48. Misfire
49. Vacuum leak
50. N/A
51. PROM error
52. Problem at Electronic Control Module (ECM) -
Missing fuel calpac missing OR
Analog to digital converter error OR
Fault at quad driver module OR
Low voltage at oil temperature sensor
53. High voltage at battery OR
High voltage at exhaust gas recirculation valve OR
Voltage reference error OR
Problem at vehicle anti-theft system
54. Low voltage at fuel pump OR
Low voltage at Fuel pump relay OR
Output failure at quad driver module
55. Problem at Electronic Control Module (ECM) -
ECM failure OR
Serial bus error OR
Fuel lean malfunction
56. Low coolant or corrosivity OR
Fault in port throttle system vacuum sensor
57. N/A
58. Problem at vehicle anti-theft system
59-60. N/A
61. Oxygen sensor degraded OR
Port throttle system error OR
Cruise control problems
62. Gear switch input diagnostics OR
High voltage at oil temperature sensor OR
Fault in cruise control- vacuum solenoid circuit
63. High voltage at manifold absolute pressure sensor OR
Fault in exhaust gas recirculation valve OR
Fault at right oxygen sensor
64. Low voltage at manifold absolute pressure sensor OR
Right oxygen sensor lean
65. Failure at exhaust gas recirculation valve OR
Faulure at injector peak/hold diagnostic OR
Right oxygen sensor rich OR
Fault at cruise control position sensor
66. Internal reset of Electronic Control Module (ECM)
67. Fault at cruise control switch
68. Fault at cruise control switch
69. Fault at air conditioner pressure switch
70-87. N/A
88. Internal reset of Electronic Control Module (ECM)
Old Jul 16, 2003 | 06:17 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok none of you have ever seen a problem like this? i mean i got the distributer a little wet and its brand new, its some accell thing. i mean i've been told that water in the bay won't hurt anything. I used a pressure washer to get off the degreeser, its like a 1200psi one.
Old Jul 17, 2003 | 12:21 AM
Car: 1989 IROC-Z
Engine: 383 stroker
It would help a lot if you found out what code its sending. It only takes two minutes to find out.
Old Jul 17, 2003 | 12:42 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
pressure washer in the engine bay probably wasnt your best move. when you wash off an engine just use a garden hose or else u may damage wires or get water into the weatherpacks connectors. take the dist cap off and make sure its dry, also make sure the shaft is dry, let it air out a few hours with the hood up in the sun w/ the cap off. also take off all the spark plug wires and make sure theres no water in either boots. just let the car dry in the sun with the hood up for a while, then try again. that should tell u where u stand and if u did any real damage or just got stuff wet.
Old Jul 17, 2003 | 02:00 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
pressure washing the engine bay is no problem at lal, i do it all the time so thats ok. you most likely just got stuff wet, but it depends on how long you let it sit before you started the car. if it was only a couple hours, that probably won't do the engine any good. I woudl AT MINIMUM leave the car to dry over night and then start it up the next day.
easiest thing to do would be to just get the code that your'e throwing.
Old Jul 29, 2003 | 06:05 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
i work at a dealership and we wash engine bays all the time, i just did one today that was a 91 jeep inline 6 4.0L and they r always fine. one thing we do tho is keep the egine running while doing it and keep it running for about 10 mins after. on the newer cars they don't always keep the cars on. we don't cover anything and water goes right on the distributer and nothing happens. go figure
Old Jul 29, 2003 | 07:32 PM
TekViper's Avatar
Engine: 3.1L v6
why do u keep the car running?
Old Jul 29, 2003 | 09:47 PM
Grimaldo's Avatar
I just tried that trouble code shooting. My car just kept on doing that sequence over and over. No numbers popped up, and it did not stop with that sequence. What does that mean?
fasteddi
Sep 10, 2015 09:32 AM
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
