dont know what it is ask here
Old Jul 17, 2003 | 01:51 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
ok i'm first wth is this thing in the pic, and can it be removed without hurting anything
Old Jul 17, 2003 | 01:52 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
another
Old Jul 17, 2003 | 02:04 PM
Spdfrk1990's Avatar
i removed mine when i installed my headers
Old Jul 17, 2003 | 02:05 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
but what is it, what does it do?
Old Jul 17, 2003 | 02:06 PM
Steve89GTA's Avatar
Air diverter valve. It is supposed to go from there to:
1. Your catalytic connection
2. To you exhaust manifolds.
There should be 2 electrical connectors in their but yours doesn't seem to be complete...
Old Jul 17, 2003 | 02:10 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
is that a bad thing or what? since its not working can i just pull it apart and remove it, i live in florida with no emissions checking. so......
Old Jul 17, 2003 | 02:17 PM
Spdfrk1990's Avatar
i would think it would send a check engine light
Old Jul 17, 2003 | 02:19 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
so how were you able to remove yours without any proplem. I hate it because its got all th pipe there and covers the beauty of the engine.
Old Jul 17, 2003 | 02:24 PM
Spdfrk1990's Avatar
I didnt actually remove it for good just to install the headers. I will remove all the emissions when i put my new engine in. I just have to get a prom burned with out the emissions.
Old Jul 17, 2003 | 02:25 PM
Spdfrk1990's Avatar
maybe get this moved to the tech board or somethin they be able to help u better in there
Old Jul 17, 2003 | 02:27 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
how do i get it moved then?
Old Jul 17, 2003 | 02:29 PM
Spdfrk1990's Avatar
either post a new 1 in the tech part or have the moderator move it
Old Jul 17, 2003 | 03:02 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok i got 2 new questions, 1, wth is this battery looking thing next to the air bix?
and
and is this stock ws6 inake running?
Old Jul 17, 2003 | 03:25 PM
Steve89GTA's Avatar
Dont' know about that intake.
The other things looks to be your fuel evap canister.
Old Jul 17, 2003 | 03:26 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I removed all the emissions stuff.
The circled thing in the last pic is the purge canister soleniod stuff. I did keep that on my car and so should you. The EEC is considered emissions stuff, but it controls fuel vapor pressure and it sends it back into the throttle body. The thing you see in the pic is the heater control valve. The 2 sensors that were on the box in question, I mounted them on top of the AC compessor, just to retain something to plug the harness into.
Old Jul 17, 2003 | 03:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It won't. The ECM does not monitor the the diverter valve solenoids nor the EVAP solenoid since they aren't critical to the engines running. It only switches them on or off so you can junk what's circled along with the AIR pump. I would also recommend keeping the EVAP canister. I remounted mine under that tray area so it wouldn't be in sight or in the way.
The air box is pretty much standard I believe for 85 to, I think, 88 or 89 TPI 'birds and also came on the v6ers.
Old Jul 17, 2003 | 04:12 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
so that intake mess is stock? I'm gonna goto home depot and get the pvc pipe i need to make my own cold air. I ordered a k&m filter from summit yesterday so it'll be here in a few days.
Old Jul 17, 2003 | 04:20 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
did those ram air type things come on any of these 3rd gens stock? i see so many of them it makes me wonder for some reason.
Old Jul 17, 2003 | 04:28 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
im 99.9% sure no 3rd gen birds or camaros came with any type of ram air item.
Old Jul 17, 2003 | 04:57 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
thx d00ds if i have any more questions be sure that i'll ask.
Old Jul 17, 2003 | 07:19 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
This forum is for appearance and detailing. If you have other questions, be sure to ask in the appropriate forum please. Thanks
