Window tint removal?? HELP!!
Old Aug 1, 2003 | 09:21 AM
tjamison2001's Avatar
Car: 85 Iroc Z28
Engine: 305 V8 TPI
What is the best (and easiest) way to remove window tinting? The previous ower put 2 layers of tint on my rear window.... The first layer peeled off without a problem. The layer unerneath is another problem. I went to the auto parts store and the sold me their "miracle" spray for tint removal As you can probably guess, it worked for crap! It took me close to 45 minutes to remove a 1 square foot area with a razorblade
Any suggestions on taking the stuff off with a little less effort? All suggestions will be greatly appreciated!!!
Old Aug 1, 2003 | 09:54 AM
Knight350's Avatar
I know what you mean, tint is a real bitch to get off. BUT there is something called aircraft stripper that is used to take clear coat off our rims, this stuff should work on tint no problem. I would give it a try on a small area first, the aircraft stripper is allot easier to clean that the tint itself.
I got the stuff from carquest. Hope this helps..
Fredel
Old Aug 1, 2003 | 10:34 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
OK question on any product somebody might bring up on this. How would you apply it? Just spray it on? Won't it run and drip on things and ruin carpet weather stripping etc. I imagine you could lay plastic over everything. So maybe a little more detail in a response as far as process and time involved instead of just try so and so product.
Old Aug 1, 2003 | 03:24 PM
Tyler-88's Avatar
i had to remove tint from my side windows a few times now. i just spray some window cleaner on it that has amonia on it and than i take a horizontal razor blade that has a holder and i just go ape on it. takes like 5mins a window
Old Aug 1, 2003 | 04:17 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
yep...it really works
Old Aug 1, 2003 | 07:49 PM
kristopheer's Avatar
what kind of razor blade holder?
Old Aug 1, 2003 | 09:08 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
when I did mine I just used a single edge razor blade(like a druggy uses) in one of those cheapie like $2.50 holder deals you find at any home depot or auto parts place around where they keep their paint at.
Old Aug 2, 2003 | 12:47 AM
Car: 85 Iroc Z28
Engine: 305 V8 TPI
I've got tomorrow off, so I'll give the ammonia thing a try. If that doesn't work, I'll be taking a trip to the scrap yard and get a new back window for $15.00 Thanks for all the tips everyone!!! I'll keep you all posted as to how it goes!
Old Aug 2, 2003 | 07:23 AM
NOCANDO's Avatar
Try soapy water. It tends to make the blade slide easier on the film. Window cleaner tends to dry up faster making it harder to scrap the film off. The trick is to spray the film and let it soak in. The soapy water will soften the film.
RyanJB
Sep 2, 2015 01:27 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
