In side wheel wells???
Old Sep 14, 2003 | 08:35 AM
1gta2c's Avatar
Has anyone painted in side the wells. Do you use spray or a paint brush. What kind of paint did you use so it does not come off. Mine looks old and dull in the light, just wondering if any one has done this.
Old Sep 14, 2003 | 10:03 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
You could try POR-15, that way it won't chip or rust again. Check out www.por15.com
Old Sep 14, 2003 | 10:14 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I had no rust in my wheel wells so I did not use por 15, however, I had real good sucess with semi flat black engine paint. It has some shine to it but not alot so if you drive it in the rain it still looks good, where as shiny would have water spots/dirt showing up.
First I cleaned it up real well, then sprayed 2 lighter coats to make it black again. I did not load on the paint. Because it is on the thin side it does not chip off. I did have a light coat of undercoating in the wheel wells, I just sprayed over that.
Old Sep 14, 2003 | 10:29 AM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
I just use this Premium Rockerguard spray can you can get from Canadian Tire. Its a nice black color and sprays on thick and kind of rubbery.
Old Sep 14, 2003 | 11:46 AM
RITcutie18's Avatar
i wonder if a spray on pickup-truck bed liner would look good in the engine compartment like rhino lining or something??? just an idea
Old Sep 14, 2003 | 12:27 PM
83 MidniteZ's Avatar
Something like that would be durable, and easy to clean (just spray off), but would draw too much attention to the wheel well. You want to use something that looks right at home and is not attention grabbing. Anything textured isn't a good idea. A flat black paint would be the best bet. Maybe a non-gloss chassis paint?
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
maroe624
Apr 16, 2017 08:29 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
wruiz
Aug 11, 2015 02:59 PM
