Just installed my H4 Silverstars (pics)
Old Sep 18, 2003 | 02:15 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
The box with my old bulbs. Sylvania is called Osram in Europe.
My headlights already were converted to H4 using Hella housings.
Day shot. The light looks a little whiter than before.
View from inside at night. The light is really a lot whiter.
Had to throw this one in because I love the Firebird's taillights at night.
All images removed- Check your images.
Old Sep 18, 2003 | 03:25 PM
Red_Demon's Avatar
From: Currently State College Pa, Usually, I live out side of philly.
how did you go about hooking those light's into the exisiting headlight power line?
Did you need to make adapters?
Last one, How did you get them into the enclosed headlight? I was trying to figure out how to cut one open and do the same..
Old Sep 18, 2003 | 03:40 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
The connectors are the same. You just have to switch the wires. And I used H4 housings. They aren't that expensive so I wouldn't bother with modding sealed beams.
Attached Thumbnails Just installed my H4 Silverstars (pics)-4656-20to-20h4-20conversion.jpg
Old Sep 18, 2003 | 08:10 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Do you have Part numbers for the H4 Bulbs and the Hella Housings?
Pweeaaaase
Old Sep 19, 2003 | 01:07 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I was already looking into this and found these sites:
http://www.zx2racing.com/store/lenses.htm
http://www.sportscar-parts.com/mivas...tegory_Code=11
http://suvlights.tripod.com/suvlight...ealed-beam.htm
I'm definitely going with the Sylvania Silver Star bulbs as well.
Old Sep 19, 2003 | 01:30 AM
Faded's Avatar
Car: '91 Firebird
I've read other posts about this, and they all said you need a set of relays to make it work right? You did this without extra relays, or no?
Old Sep 19, 2003 | 03:11 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Sorry, I can't give you the part numbers of the H4 housings since the conversion was done in 1992 when the car was new. They're probably no longer available or illegal in the US. The bulbs I used were Osram part number 64192SVS. They shouldn't be available in the US, but Sylvania makes US spec Silverstars. Also you don't need additional relays for the conversion.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
Out-Cast
Sep 11, 2015 08:03 AM
