parking lamps.....gone!
Car: 97
Engine: 3800 v6
Transmission: AUTO
i had to do it. I love this guys car so i cleaned it up a bit more.
im think about doing the same to my car. ill like rig up the headlights to act as turn signals. anybody ever done this? you guys like it?
and i think that getting rid of the seem between the nose and the fender looks really good. i hear its real hard to do though. maybe if the nose and fender were fiberglass then you could bond them together or sumtin. i dun know, but ima try to figure a way to do it....any help would be great!
(edit: oh yah, i got rid of the nose emblem,z28 badge, and red chevy logo on the grill.)
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
well okay id leave your fog lights and turn em into turns because your turns have to flash yellow and you cant have either of your head lights doing that....other then that i think its a cool mod.
Car: 97
Engine: 3800 v6
Transmission: AUTO
yeah i agree! maybe you could fit some turn signals in the headlighs too...somehow...lets figure this out !
Car: 97
Engine: 3800 v6
Transmission: AUTO
oh, what if you drilled into your headlights and added a yellow light for the turn signal.....grrr...but how would that work at night...well..i dont use my brights...
Car: '89 IROC-Z Convertible & '91 RS
I don't like it...it's too plain. I do like the one piece headlight mod though. I think FLYNLOW has done that with his ride. Very sweet. I wouldn't recommend shaving that seam off on the nose. There's a good chance it'll start cracking after awhile.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I like it a lot better on a car thats painted, but I'm still not sure if I like it that much.
To me, there is just too many things in the front of a thirdgen/fbody.
You;ve got two headlights, turnsignals/marker lamps,license plate, badge/emblem, and a big open spot for the grille.
It's all personal opinon that matters I suppose. If you were to get rid of the seam, the turn signals/makrer lights, and get one solide headlight I think it would look sharp.
To me an all white car with minimal trim,tinted windows, and what little trim is left, paint gloss black.
You end up with a pretty sweet looken ride.The absence of all those things really adds to the lines of the car (more sleek, and stealthy looking) in my point of veiw.
I belive, you can g et a filler that doesn't harden quite solid, and a paint that is semi flexible as well. If you use that instead of fiberglass/hard *** expoxy, it should flex with the car. Unless of course you hit a curb/parking stop.
Here's a little photo shop of the one in your sig
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i think with no parking lamps, it needs brake ducts in its place
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Car: 97
Engine: 3800 v6
Transmission: AUTO
how do you guys think one of them metal grills would look on the black car (like one of the ones flynlow has). i dun know if i should even attempt to photoshop that without a donor pic. anybody got one that looks close to the same angle?
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Dude, Drone that looks bad ***! Maybe you could integrate some turn signals into the front GFX or something. I did a photochop on mine like that at my site.
Car: 87 Iroc Z28
Engine: 355 TPI
What about a composite style headlight with headlights, brights, and turn signal that all fits in the orignal headlight pocket, but with a flush look like headlight covers ??? Thats what I would like to do eventualy.
Car: 97
Engine: 3800 v6
Transmission: AUTO
yeah, thats what i was thinking. intergrate it all into the headlights....but i kinda like the one color look of the headlights. but keep thinking cause i wanna find a solution because i just gotta do this mod ;o
Car: 87 Iroc Z28
Engine: 355 TPI
Here check this out, this is from the newer impallas. There is a black peice of plastic that seperates the different lights/reflectors, because this peice is black even with a clear lens it looks like it is blacked out. I think if this light were rearanged/reshaped to fit into a camaro headlight pocket it could be a good way to solve many problems. You would get a smooth look with out the receced lights, and the parkin lamps, plus it would apear blacked out yet still give really good lighting.
Some time soon I plan on getting ahold of one of these and making an attmept at reworking it to fit my camaro.
Kevin
Kevin
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
The first pic makes it look more like a race car front end. Don't care for the single headlight pic though.
Car: 00 TA, 91 Formula, 89 RS
Originally posted by FLYNLOW92rs
I think it would look good with a billet grill in there......
It looks to plain when it's ALL black....
You might be able to use the original photo he has of the shot in his sig, and mirror it.
Car: 97
Engine: 3800 v6
Transmission: AUTO
meh, best i could do with having to blow the image up so much.
but i can tell right now that the grill in there will look freakin awesome. now i just gotta figure out the turn signals and im gonna do this.
That's why I said you could use the original photo that his sig came from
Still looks not too bad.... looks like a billet grille in there would look awesome, 500% better
Car: 97
Engine: 3800 v6
Transmission: AUTO
heres an idea-
would foglights behind the billet grill be bright enough to be used as turnsignals. (assuming you tint them yellow or use a yellow bulb).
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Fog light turn signals would be TOO bright. You could either use some of those generic aftermarket side markers, or what I did for fun was drill the back of a cheapo set of fog lights out, then mount a 1156 bulb socket onto it; it became the franken light (similar to the a poor man's unerlighting, didn't use it long). You'd want to use a 1157 socket. Just a suggestion.
I had a blue bulb in mine and I mounted it so it "sprayed" out from under the front lower GFX - kinda cool actually.
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
Re: parking lamps.....gone!
But I'm still primer for the time being.
If you want any info, shot me an email @ webmaster@danielbuck.net I'd be happy to show ya how I did it (I took lots of pictures of the entire process)
I am using my stock foglights as the blinkers, and have had no complaints. If you do have some complaints, I guess you could angle them downward a bit.
Car: 1990 Camaro
Engine: 355ci
i went to post something but didnt realize i hit reply instead of starting a new thread....but i did start a new thread on a similar, yet completly different subject
Car: 97
Engine: 3800 v6
Transmission: AUTO
yeah but wouldnt you need it to be really bright to see it good behind the grill during the day? is this idea even good or am i dreaming? i dont know what those grills look like in person.
its a photoshop. i guess i did a good enough job if ya cant tell ;o
RedLeader289
May 28, 2019 01:47 PM
They are gone! lol I like it!
