another bird headlight idea
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
what if you got an extra set of blinker housings for a firebird. cut out the yellow part and replaced it with plexy glass and put a headlight bulb in it. then just put it in next to your blinkers and molded it in. it would be the perfect height. the only problems i see are heat and not enough vertical light. what do u think?
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
I believe what you are talking about has been done. Take a look at RedRaif's car (I think the name is right) and see if that is what you are thinkin about.
I also believe she tells how she did it too. (either on her webpage or on here).
-Jesse
-Jesse
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
It wouldn't project light correctly and it would melt anyway. However it IS a cool idea and can be pulled off using narrow rectangular fog lights to get roughly the same visual effect.
drathaar907
Aug 10, 2015 07:44 AM
