rear wheel picture
Old Nov 27, 2003 | 02:54 PM
carrascoZ28's Avatar
rear wheel picture
HI EVERYONE.
DOES ANYONE HAVE A PICTURE WITH 275/50/16 REAR TIRES?
I JUST GOT 2 OF THEM FOR FREE BUT I WOULD LIKE TO SEE HOW THEY WILL LOOK LIKE.
THANKS
Old Nov 27, 2003 | 07:37 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
what rims do you have on there? that wide tire will fot on the normal 8 inch wide rim that came on our cars but will have alot of sidewall buldge. I dont think it would look all that good for one and really dont think it would be all that safe on that skinny of a rim. a 265 50 is all the wider I would reccomend for an 8 inh wide rim.
Old Nov 27, 2003 | 08:07 PM
5SIZ's Avatar
Car: 1987 IROC-Z
here are 255/50/16's
I know there not 275 but then again I didn't think they made 275's for 16's, you will rub. I have 255/50/16's in the front also without a rubbing problem but I bet thats maxed.
these are my new firehawk sz50 ep's, damn good tire mind you. if you notice my exaust is crooked "you will now that I told you" it's from getting rear ended by some old bitch @ like 40.
Old Nov 27, 2003 | 08:09 PM
5SIZ's Avatar
Car: 1987 IROC-Z
here is a closer shot
"yes I know my tips need to be polished BAD!"
Old Nov 27, 2003 | 08:29 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Wow, who welded those tips onthere??!!
Old Nov 27, 2003 | 08:34 PM
5SIZ's Avatar
Car: 1987 IROC-Z
previouse owner did, booger weld mania!
Old Nov 27, 2003 | 08:40 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
275's are considerably taller than 255's.
Old Nov 28, 2003 | 09:29 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
10mm I would not say is considerably taller.
ie 255/50/16 vs 275/50/16
where as 50 refers to the sidewall aspect in relation to tread sectional width, and 255 is the tread section in mm.
an increase of 20mm section width would result in (50% of 20mm difference) 10mm hight difference.
Old Nov 28, 2003 | 09:39 AM
mw66nova's Avatar
Engine: 7.0L
they are exactly .95" taller. trust me, i know. that's alot of wheel gap difference if you ask me.
Old Nov 28, 2003 | 11:52 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Not to argue, but they should be 20 mm taller all together. There is 25.4 mm in an inch, so thats like .78" taller. Not a big difference from your .95", but still some.
So 3/4 of an inch taller then the 255's. But when were talking wheel gap its a pretty large difference.
Old Nov 28, 2003 | 12:10 PM
mw66nova's Avatar
Engine: 7.0L
well, 255/60/15~27.1"tall 275/60/15~28"tall. that's what the book says. of course. it realy all depends on the size wheel you have...
Old Nov 28, 2003 | 12:15 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
here are my rear 255/50/16's
Old Nov 28, 2003 | 01:44 PM
5SIZ's Avatar
Car: 1987 IROC-Z
are those Dunlops? If so then you have my front tires lol.
Old Nov 28, 2003 | 03:49 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Nope, not Dunlop's .
They are Phantom ZR's (255/50/zr16 in rear and 245/50/zr16 in front). Thread pattern is very similar to a BFG comp T/A ZR , but the Phantom's seem to hook a little better for a street tire.
Old Nov 28, 2003 | 04:02 PM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
275 / 45 / 18
Old Nov 28, 2003 | 04:47 PM
85_camaro's Avatar
1991 z-28 how wide are your rims?
Old Nov 29, 2003 | 11:54 AM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
Here are my Kumho 275/40R17s (for what it's worth)
Edit: I've got 40s, not 50s...
Old Nov 29, 2003 | 09:07 PM
D M N's Avatar
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
why do you want more sidewall?? ..... proably stupid question....
Old Nov 30, 2003 | 12:27 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
not sure if I agree.....I have 17X8's (8 being the stock width of the 16 inch rims)....and I'm running P275/40/R17's....and they are fine...they don't buldge...
Old Dec 1, 2003 | 11:04 AM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Bridgestone Potenza RE730 P245/50ZR-16 Tires
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
