SS Hood Woes......
Old Dec 25, 2003 | 10:19 PM
FLYNLOW92rs's Avatar
SS Hood Woes......
You can view my frustration through the following question.....
Is there any way to open the hood without using the inside lever???
Old Dec 25, 2003 | 10:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
hood pins instead???
is that what you're asking?
Old Dec 25, 2003 | 10:40 PM
I mean the hood is closed, and the inside lever doesn't pop it up......
Old Dec 25, 2003 | 10:43 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
u can try to lay down under her, and get a long screwdriver, some of them have a little tab u can hit, if not. maybe u are lucky and the cable is just stretched. then all u gotta do is pull the housing and all out, and give her a longer pull. Try the screwdriver first tho
Sorry I left this part out, The tab should be right by where you normally would be able to pop her up. u CAN get to it, if you have it. U just gotta look hard.
Old Dec 25, 2003 | 10:47 PM
xpndbl3's Avatar
Car: 1984 Z28
try tapping on the hood all around the front of it wht your fist banging down....that usually works....or pulling it all weird ways to pop it up....good luck.
now you know why i have all hood pins lol.
Old Dec 25, 2003 | 11:27 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
My hood release was sticking a few weeks agao. Once I finaly got it open I sprayed some chain lube on all the moving parts of the hood latch to free them up. Works fine now.
Old Dec 25, 2003 | 11:31 PM
That used to work when i had the spring in, now that i took the spring out in an effort to get the gap less noticible, it doens't work anymore......
I'll give a look for that tab tomorrow when it's light outside, thanks for the tip.....
The lube probably sounds like a good idea, dirt has probably been building up in there for years......
Old Dec 26, 2003 | 01:14 AM
stiers's Avatar
Did you try having someone hold the lever back and someone pulling up on the front at the same time? If that doesn't work I would try spraying WD40 or some liquid wrench through the hood gap into the latch. If all else fails get under it and find something to push the latch with.
Old Dec 26, 2003 | 01:27 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
well, that's probably one of your problems right there.
Old Dec 26, 2003 | 01:45 AM
Yeah, once i get it back open the spring will be re-installed.......
Old Dec 26, 2003 | 04:49 PM
Daishi's Avatar
Yeah i would definitly, get a friend to pull back the lever and u just try and pull it up. the lever is probably working, it just doesn't "spring" the hood up...... I wonder why
heh heh
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
