Yet another Ram-Air II alignment problem
Car: 00 TA, 91 Formula, 89 RS
I got my RA-II hood today (I ordered it yesterday... go Hawks Thirdgen Parts!!!)
I've been working ALL day to try to get it align properly, and this is the best I've gotten it. I've removed all unnecessary hardware (the latch, the spring, the bump stop things, etc.) and still can't get it to align right. Are there any suggestions besides sending it back? I've seen other people manage to get theirs to fit well. I didn't have a problem with my Formula hood.
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
You removed the latch??? Um, ya kinda need that... Put the latch BACK in, and put it to the lowest possible spot you can get it. Then, where the Radiator support goes up from the sides, my hood was hitting there, so I had to bang it with a hammer to take it down a little, and that helped a lot. It's where the front member that goes from side to side of the car, raises up like 1" to where the caution fan cover goes, the sides of those I had to bang down. If you have the bump stops out, and do what I mentioned, that should help a lot. If you don't know what i'm talking about i'll get a pic for you. I also raised the stops in the rear on one side to lower the opposite front side.
I placed Washers between the Hood and bolts on one side in order to push the hood to align better with the fender on the other side......
As far as the front........I gave up and am having Roy look at it........
the hood that hawlks sells is good quality. your front bumper may be to low look at the supports! i bought one for my brother for x mas and i took 1/2 hr to line up heres the link to the pics.
https://www.thirdgen.org/techbb2/sho...hreadid=216662
Originally posted by confucius101
i got mine from ascd
after about 3 hours and cutting 3 different locations
on the hood i well sort of got it to line up almost right
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Time to get the body shims out.
Looks like it just needs alot of love, that fit is terrible. Every time I see one of these RA hoods just makes me glad I picked a cervini's, and at the time no one had heard of them. I put my hood on and about 5-10 minutes of adjustment and I was done. Perhaps I just got lucky, or that my car was pretty square.
I love the Cervini cowl, and if I had a later thirdgen Camaro it is the hood I would get.
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Did you have to replace your front end at some point?? Thread Starter
The car has been in a front-end collision before; however it doesn't appear that anything else has been strangely adjusted or mis-fit, and the Formula hood fits perfectly.
If I were to shim the fenders up, do I just unbolt all of the fender bolts that are under the hood and pry it up with my fingers, stick some washers in there and then bolt it down, or do I have to remove lower bolts also?
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I've found it rather amazing how the slightest adjustment to one bolt here or a bump stop there can make drastic changes to the way the hood / front end sits and fits together. I had no idea it was that "touchy", if you will.
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I'm hoping that the right combination of shimming, tweaking, coaxing, and talking nicely will at least get me a decent fit. In all honestly I'd be satisfied with a mediocre fit (otherwise I wouldn't have purchased an aftermarket fiberglass hood), but I have yet to get even that IMO. If you or anyone else has some more suggestions I'd love to hear them.
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Ahhh, you dont seem to be the most experienced on this subject. I work at a body shop so my suggestion is that you should take it to a shop and have them do it, dont unbolt the fender and move them, thats just gonna create a lot more issues you dont want to deal with, trust me, i deal with used and new and aftermarket parts ( **** the aftermarket for that fact) takes carefull massaging to make a part fit. Do yourself a favor and save a headache and take it to a shop, shouldnt be much at all.
Engine: 5.7L TPI
Axle/Gears: 3.42:1
What exactly do you mean by "massaging"?
Car: 1989 Pontiac Firebird Formula 350
I have one of these hoods on my car and it fits fairly well. I do still need to do some work on a few things to make it fit better. I did notice that on mine, the drivers side sits up a little to high. In the back where the windshield wipers are is the screen to keep debrit out of that area and it sits up to high and mine is resting on it and it pushes up on the hood. I havent decided whether I am going to take the screen out or cut the screen down so the hood will sit a little lower. I hope this helps. You can check out my site to see what I did to put it on if you would like. http://www.cardomain.com/id/kitt350
Car: 1992 Camaro
Transmission: auto
How does the hood fit on the other side, not the driver's side I think you have pictured with the wide gap. If it is close on the other side a possibe fix is when you are first bloting the hood to the rear hinges you have to be careful and not lean and possible push the hood hinges to one side or the other. The hinges on your car and many other manks and models are limber and can cause the hood to shift from out center to either side. This suggestion will only help you IF the other side of the hood is close to your fender I mean real close. Hope this might help See Ya Rex
I've pushed the brackets over as far as they will go without drilling new holes. Thx for the suggestion though. Any other ideas?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine sat like this with minor adjustment,
More pics,
http://www.transamws6.com/pics/formula/hood1.jpg
http://www.transamws6.com/pics/formula/hood2.jpg
http://www.transamws6.com/pics/formula/hood3.jpg
http://www.transamws6.com/pics/formula/hood4.jpg
I then traded it for this one, which I prefer more,
More pics,
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Well, none of your front facia is aligned properly. The headlights should be flush with the front end of the fender. And the bumper cover should be the same at the curve point where it meets the fender. Get everything aligned properly before putting on the hood. Granted, the hood probably still wont fit, but atleast everything else will be right.
Car: 87 IROC Z28
If the other hood fit perfect and this one doesnt fit with the fender at all, there is no need to move the fender. The only time you move the fender is when the hood is sitting down nice and fluch and there is a very little difference in the gaps, then you just loosen the fender and push or pull, never unbolt. This comes as second nature to me, but experience is the **** i guess...and only being 19....yeah, im good. ha.
hey zepher how did you get your factory rims so clean?
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
I've got a question on shimming... does it have any side effects, like noises or does the body panel creep significantly??
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Originally posted by Goumba T
I second that. The high cowls always look odd on Third Gens, that height is perfect. Looks like it came from the factory like that. Nice job!
Shims are a normal thing, if you take your car apart now you will find a bunch.
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Originally posted by hawksthirdgen
Hey fyrelance, Give me a call if you haven't got it adjusted yet and I will try and give you some advice and suggestions on adjusting it.
Thanks,
Bruce Hawkins
Hawks Third Gen Parts
864-855-2694
Thanks,
Bruce Hawkins
864-855-2694
I will probably end up giving you a call some time this week.
Geez, the fitment of those hoods is terrible. From like 10 feet and beyond the fit seems ok, but up close I don't think I could take it.
I heard of people using a heat gun while applying some pressure to the warped area to mold the hood into perfect alignment.
GeneralIesrussi
Sep 3, 2015 03:23 AM
