very nice i think i will get it!
Old Jan 27, 2004 | 07:50 PM
icebird_1981's Avatar
lil info needed?
sup people below is a pic of my valve covers i think they are tall valve covers are they? also i got full rollers so that mean what ever valve covers i decide to buy they have to be tall ones right???
also does it make a diffrence were the pcv hole and breather holes is located...does it have to be the same spot?
thanks in advance
any info on this topic would be great dont wanna order/bid on the wrong thing..
Old Jan 28, 2004 | 05:49 PM
kevin arnold's Avatar
Car: 1987 ta
Engine: 355
Transmission: t 5
no, you have the short valve covers. i hope this is not some sort of joke, you have a bunch of stuff done,did you do it your self? you may need the tall with roller gear{not sure} have a nice day kevin.
Old Jan 28, 2004 | 05:52 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Dude if you got full rollers under those valve covers I'd like to see how you did it
Old Jan 28, 2004 | 05:55 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yeah those look like they are too short to fit roller fulcrum rockers in there.. I'd check to see what you have first...
Old Jan 28, 2004 | 07:24 PM
no i did not build this engine i got it it with alot of work done already and i am just trying to pick up were the dude left off. I did not know if it had rollers at first so I had a mechanic shop to check it and let me know if had them and the dude said it did. lol i dont know much about cars but I am learning a lot I know the basics though lol..i learn as i go along and learn a lot off this site. so no this is not a joke i am just a beginner trying to learn about cars by asking questions on this site and people I know. so please dont mind my stupid questions lol.. so what u guys are saying is that there can not be roller on because my valve covers?? so what do tall valve covers look like?? i seen pics of tall valve covers on the net and they all looked the same size as mine so that why i though i had tall ones.. guess not..pluse i seen other valve covers that are lower then mine and i figured they were the normal ones..
how can I tell for sure if I got rollers or not?
oh when i say full rollers i dont know if there is a half rollers or what...dude just told me i got rollers>theres a perfect example that i dont know much lol
Old Jan 28, 2004 | 08:15 PM
thirdgen88's Avatar
Car: 1995 Corvette
You could have roller tip rockers... Roller fulcrum rockers (or "full roller rockers") have roller bearings for the tip and for the part that goes onto the stud... For full roller rockers you also need to use a different type of nut (they're called poly-locks) that uses an allen set screw to fix them in place (as opposed to the pinch thread design of a stock rocker nut)... Because of this, you need more upward clearance in your valve covers...
Ok, here's a picture to illustrate a tall valve cover.. This was my '88 bird which had crane full roller rockers... You can see I have the same valve cover hold downs as are on your car... Look how little space there is between the T and the top of the valve cover...
Hope this clears things up a little...
Old Jan 28, 2004 | 08:23 PM
oh i get it..sry my bad i did not know there was a diffrence..i called the mechanic and he explained it...i dont have full rollers but got rollers..thanks people and sry for the mis wording..i really did not think there was a diffrence.
thanks
Old Jan 28, 2004 | 08:41 PM
thirdgen88's Avatar
Car: 1995 Corvette
No problem... At least now you know that you don't need the really tall valve covers (which can be a pain as far as clearance with the a/c box goes)...
F-body-fan
Jan 12, 2023 01:49 PM
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
