Will Well Prostars wheels fit over my brakes?
Car: '91 Formula
Transmission: TH350 built
I have a 91 Firebird with the WS6 package, disk brakes all the way around. I like the regular prostars better than the XP ones because they are lighter and cheaper. I heard i Might have to grind down my brakes to get them on though.
Is this correct? I guess I can use the XP's if I have to.
Larry
Larry
Car: '91 Formula
What lug nuts did you use? They sent me SST Mag 12mm x 1.5 open ended nuts. I like the closed end better for looks I guess. Can I use those?
Havent even tried these yet, Im still at work
Car: '91 Formula
I see them on the mcgard website. I guess I will make sure of the size first. The ones they sent are 12mm x 1.5, I think this is right, but they are open ended for extra long racing studs. The closed ones look better, I just need to make sure I can use them. They Mcgard website has some 12 x 1.5 extra long shank for Weld and Crager wheels, and they are closed end, I think these are the ones
1992rs/ss
16
Jan 28, 2016 09:58 PM
