Water spots, wont come off...
Old May 18, 2004 | 11:52 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
alright lately my car has been parking where our sprinkler system is able to spray it, well the water is pretty hard here and i have water spots that absolutely wont come off. How do i go about doing this?
I mean while i was washing it i could feel the apint was rough and once i dreid it, the water spots were visible. How do i remove this shizzle??????
Shane
Old May 18, 2004 | 12:00 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Meguire`s # 3 cleaner/polisher then a coat of there gold class wax..it won`t happen again
Old May 18, 2004 | 12:01 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
yeah i've got the gold class, i just need to get that cleaner polish, thanks man, i'll take a trip to autozone now.
Old May 18, 2004 | 12:56 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Axle/Gears: 2.73 posi
White vinegar will also break up waterspots.
Old May 18, 2004 | 04:03 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Tried that once before, didn't work too great.
I used:
https://www.thirdgen.org/techbb2/sho...ht=water+spots
There ya go.
Old May 18, 2004 | 04:10 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ooopps i forgot to tlel everyone about my trip to autozone. I went there and asked the guys, "what is the best stuff you got to get rid of hard water spots on paint?" He said "down that isle, its Simple Green for Automotive Use." I picked it up and it was way cheaper then the other meguires stuff said before so i bought it. Came home, read the direction to see if it says dont use on paint, anything like that. It was cool. so i sprayed it on in a small spot to see if it removed the spots. BAMM after one whipe they were gone, liek that, in an instant.
I reccomend using this stuff, seemed to work great and its for use on boat gel coats also so i figured it would be ok on paint.
Shane
Old May 18, 2004 | 04:21 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
would this take it off windows, tried using some steel wool , maybe i need something thicker, im to lazy to go buy some window polishing kits
Old May 18, 2004 | 04:23 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
i bet it would take it off windows... just let it soak on the surface froe about 10-15 seconds then wipe.
Old May 18, 2004 | 04:41 PM
Car: 1990 firebird
Engine: 3.1 v6
alright cool, im going to have to take a trip to autzone, simple green correct... im going to have to look for myself, only old people and chicks work in these car places around here . very frustrating when u need to get something or ask a question
Old May 19, 2004 | 01:49 PM
BurninRed89's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
water spots on my car as well? im gussing that whats they r they rnt comin off so i think ill make a trip to auto zone also
Old May 20, 2004 | 04:32 AM
Kandied91z's Avatar
simple green is not safe on paint..........should have used a clay bar or some light polish compound. however, glad you got it fixed one way or the other. better be sure to use heavy amounts of wax now that you've opened up the clear coat.......that is if your car had clear coat.
the person that told you to use simple green on your paint needs to be beaten and dragged down the street.
Old May 20, 2004 | 09:20 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
use Mothers 3 step polishing set. 1- cleaner(will remove water spots) 2-polish 3-sealer
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
LC2 TECH
Oct 13, 2015 11:53 PM
aaron7
Sep 30, 2015 09:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
