Zaino vs. Liquid Glass
Car: 83 Sport Coupe
Engine: 383ci
Transmission: turbo350
I just tried Liquid Glass on a dark blue car. Fantastic stuff with a deep shine, no streaking, a whole lot cheaper than Zaino and easy on/off. Anyone use both of these and what one do you think is better?
Check Out My Website
Sharons Virtual Junkyard
I have used both. One thing I noticed with Liquid Class is that I got real fine scratch marks when I used it. I am not knocking it because it does work.
Zaino is not really any more expensive than your Liquid Glass. The last time I saw Liquid Glass it was around $12 or $13 and that is about what Zaino’s Z2 cost. You would need to purchase a bottle of Z1 but that should last you a couple of years. You will use a lot less Zaino as compared to Liquid Glass so I think that in reality Zaino cost is about the same if not cheaper.
88 IROC convertible
So slow it is timed with a sundial
[This message has been edited by Chuck Everly (edited September 11, 2000).]
88 IROC convertible
Does Zaino have to be removed with mineral sprits and 00 Steel Wool? That kind of bothers me.
If you were told that please don’t do it. To remove Zaino only use 100% cotton towels. It is VERY easy to remove.
I would wash the car with Dawn dishsoap before using Zaino the first time.
Car: 83 Sport Coupe
Engine: 383ci
Sorry that didn't sound right! The instructions on Liquid Glass say that if you need to REPAINT, it must be removed with steel wool[This message has been edited by sharon (edited September 11, 2000).]
My old man just had his '65 Vette repainted and the body man suggested never to use Liquid Glass or similar products due to the fact that they cannot be removed. Paint and wax stripper will just bead up on it. I suppose if your car is a trailer queen and inside a climate controlled garage it would be ideal...
Just my .02!
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
69 Firebird - Chevy 327 - Black/Black - SOLD 7/4/00
Just my .02!
Car: 1985 Trans Am
Axle/Gears: 3.70
My body guy did have a bitch of a time removing the paint on my headlight doors with the zaino on but everything else came off pretty easily. I could see where prescuffing the paint may aid the stripper adhearing to the surface but that shouldn't add that much work to a repaint job.
well anything that was not 100% removable is not worth putting on the car is my 2 cents.
Zaino can be removed with clay, rubbing alchohol or 3M wax/tar/adhesive remover, or any abrasive polish (obviously)
Zaino is cheaper in the long run...Liquid glass is very nice however...
folks,
who makes liquid glass ? I can't get Zaino down here without waiting a couple of months via sea freight so I'll try anything that's local.
ciao
gruNT
near stock 86 LG4 WS6 T/A
Brisbane Australia
http://web.one.net.au/~grunt
ciao
gruNT
Brisbane Australia
I've used both and I have to vote for Zano...Really easy and a deeper than deep finish
Hank
87'IROC Z28
Hanks 87 IROC
Hank
87'IROC Z28
Hanks 87 IROC
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I am a Zaino user, 100% Nothing I have tried is anywhere near as good, and believe me, I have tried a huge number of products.....
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tyeo098
Nov 30, 2015 06:27 PM
