window problems
Old Sep 19, 2000 | 01:42 PM
Reznor's Avatar
window problems
hey... Im having 2 problems with my windows. 1 is that when I roll them up & down they seem to scratch the tint on my windows, what to do? The second thing is I need to know what the lining/striping is called that covers both sides of the windows(& how much $$) because I need to replace it. Mine is all torn and when I roll up my window the strip seems to hang off the side of my door & flap around. THanks
You know what they say. Injection is great...but Id rather be blown!
Old Sep 19, 2000 | 03:14 PM
scauffiel's Avatar
They're probably getting scratched because your seals/stripping is shot. I'm not sure what car you have but for a Firebird/Trans Am (hell, they're probably the same for Camaros too) the numbers are as follows:
The outer stripping: Driver side 10124265, Passenger side 10124264 - $18.98 each
The inner stripping: Driver side 12394511, Passenger side 12394510 - $46.75 each
The inner stripping is expensive because it is the entire door panel top plastic piece - that's the only way you can get it from the dealer. Call Dal at VanDevere Motors, tell him you got his name on the Internet Thirdgen site for a discount: 1 (800) 362-9494.
Steve
Old Sep 20, 2000 | 01:51 AM
Reznor's Avatar
thanks for the reply.I drive an 86 IrocZ..is any of the info different?
Old Sep 20, 2000 | 10:34 AM
Lostsol's Avatar
Howdy there, one other possiblility could be the brace pieces inside your door. They look like an L shaped chunk of metal that bolts to the door with a ten mm bolt, and the bottom leg of the L is covered with felt like material and they simply support the window. There is one about 8" to 12" from the back of the door, and another about a foot past that one towards the front. They are underneath the upper plastic trim piece on the inside of the door. Cost is like six or eight dollars a piece. Just one more thing to look into, take care now.
Old Sep 20, 2000 | 12:54 PM
scauffiel's Avatar
Don't know brother, call up Dal and ask him. Just tell him you want to double check these numbers for your ROC...
Steve
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
neekolzun
Aug 24, 2015 04:59 PM
