Best set up for z06 rims and tires.. such as what sizes
Old Jun 5, 2004 | 10:33 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Im really not sure what is the best for my car . plus later on i will have some nice power from a 350. i was thinken maybe 18x9.5's all around, not sure about tires i want low profiles though. i would appreciate anyone who can help to find the best set up for these rims thanks
Attached Thumbnails Best set up for z06 rims and tires.. such as what sizes-z06rimmm.jpg
Old Jun 6, 2004 | 12:03 AM
IROCFAST's Avatar
how about 9.5's up front and 10.5's out back with a 275 and 295 both 35 series.
Old Jun 6, 2004 | 04:02 AM
Kandied91z's Avatar
that wide all around sucks, but at least go wider in the rear then front.....do as you wish though. still have some adapters that will fit those 9.5 fronts for cheap for ya.
Old Jun 6, 2004 | 08:01 AM
IROCFAST's Avatar
What size would you reccomend up front then?
Old Jun 6, 2004 | 11:46 AM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I'm pretty sure the smallest size they have is a 9.5" wide. If you're gonna go 18's get the 9.5" for the fronts and the 10.5" for the rear. If 17's, theres only one choice i think and thats 17x9.5's. btw, if you decide on the 18's, i'm selling mine that are brand new for a good price.
Old Jun 6, 2004 | 04:29 PM
Car: 2002 SS
Engine: Ls1
well i heard alot about 10.5's in the back with the 18's and that it rubs with hard acceleration or if people are sitting in the back also take in to mind that im going to be dropping my car 1-2 inces
Old Jun 6, 2004 | 06:59 PM
Kandied91z's Avatar
the back isn't the problem, it's the front and even neither is bad depending on your drop and where your adapters put your backspacing/offset.
i had 18 9.5/10.5 and it worked out alright, took alot of work to get just the right offsets but i later got rid of them because i couldn't lower the car as much as i wanted.
17's are available in 8.5 and 9.5. anywhere between 8 and 9 is more then fine for the front and anything between 8-11 is fine for the rear depending on the drop with 10's being about as wide as you would want to go with a real extended drop and not need major modifications.
i'd either go 17's with the 8.5/9.5 front/rear combo or the 18's in the 9.5/10.5 setup.
here is a picture to show the two side by side....you should be able to tell which is which. either way if you stick to either 17's or 18's it will look fine, go with an 17/18 setup and it looks out of place.
good luck.
Attached Thumbnails Best set up for z06 rims and tires.. such as what sizes-1-jeff-roy-2
Old Jun 6, 2004 | 07:08 PM
Car: 2002 SS
Engine: Ls1
im gunna have to say that the 18" set up is much nicer .. in my opinion. so what is the best size tires for these rims? also best spacers with a 1-2inch drop
Old Jun 6, 2004 | 08:31 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
i'm gonna say something like a 255/40 or 245/40 in the front and a 295/35 in the rear. Thats what i was gonna use. Since you're in DE, if you plan on ordering the 18's, come take a look at my set before ordering them.
Old Jun 6, 2004 | 08:49 PM
Car: 2002 SS
Engine: Ls1
why you dun like them? we coulda met up at the o.c car show
why you want me to check out your 18"s?
Old Jun 7, 2004 | 02:16 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I'm actually trying to sell mine right now cause i'm actually gonna be ending my project. I've never mounted this wheels and would like to sell them local to avoid shipping. They are still in the box and in teh wrapping.
Old Jun 7, 2004 | 07:38 AM
nolanr0413's Avatar
Car: Trans am
18s look better , esp if you show your car , then deffy go with 18s. I would have to bet that 17s will handle better b/c they have more sidewall than the 18s. But id go with 18s. thats what i went with .
Old Jun 7, 2004 | 12:04 PM
irocz eric's Avatar
Car: 86 "Ram Air" IROC
Engine: 305 5.Slow
Der, I may be interested in the wheels, how much u looking to get for them? Do u have the spacers?
Old Jun 7, 2004 | 12:14 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I paid $1250 for them. I don't have the spacers. I was looking to get $1000 for them and i can meet locally.
Old Jun 7, 2004 | 05:44 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I have personally disaprove of 18s and above on any third gen.
I have yet to ride in one that is comfortable, and more importantly predictable.
Thoses riveted z06 replicas are pretty sweet in 17.
Someone buy them already and post pics.
Old Jun 7, 2004 | 07:58 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
18's only ride worst because of the low profile tires people get. If you get low profile tires on a 16" wheel, it'll ride uncomfortable too. As far as predictablilty, i'll say the 18's may make it worst, but not that much. 18's look way better than the 17's though which is what i think they're after.
Old Jun 7, 2004 | 08:02 PM
FLYNLOW92rs's Avatar
I think the opposite of those on the boards, I think that a thirdgen needs a wheel at least 17" big...........that's another debate
But to this thread, i agree with Kandied, you may want to re-consider putting 18x9.5 wheels in the front
18x8 will be perfect
Old Jun 7, 2004 | 08:03 PM
Car: 2002 SS
Engine: Ls1
der i'll buy them from you for a grand if their brand new 18's 9.5 and 10.5
Old Jun 7, 2004 | 10:32 PM
Kandied91z's Avatar
if they made 18x8 or even 18x.5 or 18x9 being max i probably would have kept mine. 9.5 in the front just doesn't cut it for lowered cars.
as far as ride though, the only thing i see different is cost and weight. my 18's rode just as nice as my 16 and handled better through turns although i could have bought my rims and tires for the price of one 18" tire.
it's true lower profile tires are harder on the suspension since there is less give for bumps but they aren't that bad if your suspension is good. if you wanted a smooth ride you wouldn't have bought a camaro. you just have to evaluate your needs and go from there.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
