Can't get car clean.
Car: 1999 Trans Am WS6
Transmission: A4
I wash my car with Mr. Clean Auto Dry and use one of those mits to scrub with. When I'm done the car still looks dirty. The car is shiny but to me it still seems like I'm still seeing dirt. Any tips on what to do. I need to wax it but I don't want to if there is still dirt there.
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
You might try using a claybar on it. I've never personally used one, but many people on the boards have said it removes dirt that normal washing won't remove.
I don't know where they are sold, though. I went to AutoZone to look for one and couldn't find anything.
Car: 1989 Firebird
Engine: 5.7 LS1
Does it look dirty if you wash it normally, or is it just the mr clean stuff?
Could Use the 3 stage stuff that mcquires makes Step one is a paint cleaner, step 2 is a polish and step3 is the wax, then after that it should be as clean as you can get it with out major work, you could always try wet sand and polish, or like above use a clay bar do a search and you will find several places that sell it but you will not find it at most discount auto places
You have to make sure you wash EVERYWHERE with the mit!
If you have any second thought on if you missed a spot, redo it. Only takes a few seconds. If you have used the filter on Mr. Clean more than 3 times and you just got it you have to replace it with a new one. I have a black honda civic and a dark blue 4 wheeler and aslong as i whipe down everything!!! with the mit i never have to dry them off by hand. Make sure to watch the meter on your filter, if it starts to turn brown replace it.
Linson
Aug 21, 2015 02:12 PM
