Fog lights?
Old Sep 13, 2000 | 07:36 PM
Monkie's Avatar
Fog lights?
Ok I want to put fog lights on my 92 RS REALLY BAD! But I cant find anywhere that has new factory ones for my car. The only place I found was Next Gen, and the grille is $64.95 and the left fog light is $109.00 and the other light is $109.00 also! How can a setup for fog lights cost over $250!?!?! I mean thats just crazy! So...What I thought was that I could get just the grille and get my own fog lights. Have you guys got any good sites for me??
Old Sep 14, 2000 | 12:12 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Check eBay. Also there are some ThirdGen used parts dealers that I have used for other parts I copuldn't fing at a salvage yard. Trust me, you won't find these at a pick-a-part yourself.
Try these links as well. Good luck, Lon.
http://24.1.172.2/garage/ http://www.nos.net/davato/
Thirdgenparts.com www.thirdgenresource.com
Old Sep 14, 2000 | 05:18 AM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
The grill is like 42 bucks from classic industries. For fog lights I picked a little bit cooler aftermarket version cause I didn't like those boxy oems.
Old Sep 14, 2000 | 08:35 AM
Cntrvrsy's Avatar
Yeah, aftermarket 1s r better. I have a set of PIAAs on my IROC. They r expensive but great quality, they shine brighter and better than my headlights.
Old Sep 14, 2000 | 05:20 PM
Monkie's Avatar
Could I get the Z28 grille and put in 2 fog lights where there supose to go but just have them be aftermarket ones? If so Could I get the stock foglight switch that went under the light turn on/off stick? Would that work? And how hard would it be? Thanks alot!
Old Sep 14, 2000 | 10:03 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Dunno if this helps, but amazingly enough,
Pep Boys sells a set of foglights, that are
the _EXACT_ size and dimentions of the
T/A fog lights for like 29.99..
I dunno what the Camaro fogs are like,
can't remember if they were the same.
-- Joe
Old Sep 16, 2000 | 01:48 PM
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
The firebird fog lights are slightly different, the trim only goes on the side of the light and the camaro ones have full trim around the entire light, but they may work. I had the same prob with mine (the old ones had cracked lenses and the frames were rusted) and i looked everywhere for 3 years for used ones till i finally bit the bullet and went to GM. Try going to a GM dealership, i got mine for $80 each and i also got a 92 grille with the chevy bowtie for $32.50.
'86 IROC-Z Restored Stock Show car
305 TPI Silver Glasruit Paint/Red deluxe Int
Old Sep 17, 2000 | 09:54 PM
CG's Avatar
CG
hey check out www.thirdgenresource.com, they are in NC, i bought my Z-28 hood from them, its actually the hood of the guys own perosnal car (the white Z on the site) if i remember correctly their prices on fog lights were really good and they were factory also.
Old Sep 18, 2000 | 07:15 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There are a bunch of aftermarket fog lights that are the same dimensions as the stock camaro fogs. They are not the same, but from a distance they look pretty similar. I opted to restore my factory fog lights instead of go to aftermarket, just because I'm **** about stuff like that.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 22, 2000 | 05:22 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
You can get a good deal from Classic Industries on the grille. And I've seen alot of camaro's with aftermarket fog lamps which I thought looked way better than stock.
I'd avoid Nextgen unless you absolutely have no other choice...they are very pricey
Old Sep 24, 2000 | 02:15 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Wal-mart special $19.95
<A HREF="http://anzwers.org/free/gta" TARGET=_blank>87 Firebird
84 Camaro</A>
- intelligence is learned, ignorance is universal
Old Sep 24, 2000 | 03:23 PM
Monkie's Avatar
LOL those look awsome! But are they good? and how bright are they?
Old Sep 30, 2000 | 10:43 AM
jm91rs's Avatar
I had the same problem you had. You can get the grille for about 40 bucks from www.tacreationsusa.com and then I bought the foglights from Pep Boys. They were 29.99, but aren't the exact dimensions of the actual z lights, but they are so close, no one can tell. I saw them on my friend's z after he got new ones and I thought they were real, even when I knew the exact dimensions of the originals. The ones I have are made by RALLY, they come with these dumb flip down covers,but they come off no problem (just pop off). They are very bright and come with a switch, but I went ahead and got the original switch from chevy because it looks better than a tacky red switch. I don't have a pic of the lights, but if i did, you wouldn't be able to tell the difference from originals.
91 rs convertible, K&N, Edelbrock open element cleaner, 3.73, B&M shifter
Old Sep 30, 2000 | 10:49 AM
jm91rs's Avatar
Oh yeah, the switch was like 15 bucks or so and it was simple to wire. One for power in when your running lights are on (just tap into a dash light like your ac light). One for power in for the actual lights. You can wire it so they go on with your running lights, or headlights, or just whenever (like I did). One for a ground. One for going to the fog lights. Simple. The original switch is so much better because it lights up at night like the rest of your interior and when it is on, a green light is on it. The switch looks great.
Old Sep 30, 2000 | 01:37 PM
deadbird's Avatar
Engine: TPI 305/ v6
I can't remember for sure but i believe they are 55 watt lights. They are bright enough to drive around w/o the mail headlights on and they seem to be bright enough to **** people in the oncoming lane off. I simply took the grilles out and then trimmed the screw tabs off with a utility knife. The lights are bolted to the impact bar. I bought a relay and wired it to my parking light so they turn on/off when I turn on my parking lights.
Old Sep 30, 2000 | 07:57 PM
Monkie's Avatar
Thanks for all the help guys! Im thinking about getting some fogs either next weekend or the next. Jim91rs you said that you got the original fog switch. Im taking it you mean the one that goes under the main light ****? And was it easy to wire it up?
Old Oct 1, 2000 | 12:02 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
AMEN to the $19.95 Wal-Mart specials.....! I've got a set of those BLAZER fog lights on one of my '88 GTAs and they work just fine.
They are 55-watt bulbs just like the OEM factory units. They used to also carry 110-watt bulbs, but I didn't see any the last time I had to buy a new bulb. I get flashed all the time over the 55-watt bulbs. The light housings are not metal like OEM ones, but you can always take the "guts" of the light out and install into the OEM housing if it's still good..... that's what I did and they work perfectly.
A great money-saving set......
Frankie Rider, 2
The GTA Source Page
1988 GTA Red 5.7L Hatchback
1988 GTA Black 5.7L Notchback
1988 GTA Gunmetal Metallic 5.0L Hatchback
[This message has been edited by FrankieRider2 (edited October 01, 2000).]
Old Oct 1, 2000 | 12:20 AM
jm91rs's Avatar
yeah it is the one that goes under the headlight ****/switch. The foglight switch has the yellow picture of a light, just like the interior lights on the rest of the car. When I turn my running lights on (**** half-way out) , the fog light picture on the switch lights up so you can find the switch at night. When I turn the switch on, a green light lights up to show you they are on. It is very simple to wire, basically I just figured out what prong on the back of the switch controlled what by using an multi-meter. I could probably see if I wrote it down and tell you if you want. One was a ground, one was tapped into my AC light (so it would light up with my interior lights), one went to the fog lights, and one went to the fuse box (you could wire it to the fuse box for constant power when the car is on by wiring it to the fuse that the radio is on. Or you could tap into the running lights so they come on when the lights are on, or you could tap into one of the headlights so they are on when the headlights are on, and they go off when the brights come on, but with the fog lights, you really shouldn't need the brights.) hope this helps
Old Feb 16, 2005 | 05:48 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Think you could write that wire diagram down I found a factory fog light switch in the yard and some fogs and Im gone hook them all up like you said with the factory switch
Old Nov 23, 2006 | 11:55 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Hey guys, I know this is really old and all, but can some one tell me how hard it would be to get these and wire them to turn on and off with the car? I have heard that people that drive with lights on are 33% less likely to get into an accident, and I have trouble remembering to turn off my headlights.
Would it be as simple as grounding and then sending the positive to the alternator?
Old Nov 24, 2006 | 06:33 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
They may be 33% less likely to get into an accident, but I am 50% more likely to want to head on collide with the car that has it's lights on during the day. I'm sure it wouldn't be hard. Just tap into a circuit for your relay that has power only when in the run position of the key, IE ignition, or something similar. But god that would be annoying, at least to me. I dunno if anyone else loathes DRL.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
