Ground FX removal question.
Old Oct 2, 2000 | 05:54 PM
N3ZNF's Avatar
Car: 89' Chevy IROC
Engine: L98 350
Hi,
A friends doing a little body work on his 87 TA and has to get the ground fx off. Any tips on how to remove them, particularily the rocker panel (area under door between tires)? Thanks in advance for any help.
Martin
Old Oct 2, 2000 | 09:08 PM
nestz28's Avatar
I just did this a few months ago. For the rockers, it's kinda hard to explain, but remove the screws in the door jamb, then look on the bottom under the car, there should be more screws, remove them. If you have emblems, you have to remove them because there are 2 screws under them. There are 3 bolts under the car, 2 in the back and I think one in the front, remove those. now the front should be movable, and the back is held on by this clip. If I remember correctly, you slide the piece towards the back of the car and then it's free. Just make sure you take out all the bolts and screws and go easy on it if you don't want to break it. The front piece is easy. there are a whole bunch of 10mm nuts that hold it on and you just have to take those off. A deep socket will help here. Using a wrench is a PITA, so make sure you have a socket.
Hope this helps!
Old Oct 2, 2000 | 10:08 PM
Sandman's Avatar
This is what I need to know how to get the scews out of the back and front the ones that are screwed in to the fenders.
THANKS
Old Oct 3, 2000 | 12:59 AM
silvermelon's Avatar
on my 86, the rear of it was held on by a bolt too, i had to remove the back seat and the panel to get to it.
Frozer!!!
Jan 19, 2024 04:55 PM
ktthecarguy
Jul 5, 2020 11:46 AM
downsouthboy
Aug 29, 2015 11:29 AM
Glowsock
Aug 26, 2015 12:28 AM
3rdgenparts
Aug 8, 2015 07:09 PM
