fender hitting tire
Car: 91 Z28
Transmission: built 700R4
fender hitting tire
On my new Z28 I have 17x9.5 TT2s on the back with a 285/40/17 and sportlines. I drove it all the way from Nebraska to MD and there were quite a few bad roads inbetween. On the back right tire the inner fender lip has rubbed a few times going over some really big bumps and has sliced into the tire. Does anyone have some sugestions on what I can do to fix this problem? could I take a rubber mallet to the rough edge and bend it in a little? thanks for any advice.
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I had to clearance my inner front fenders for my tires. I just used a small sledge hammer and whacked away. If its the lip of the fender that is hitting, you can have the edges rolled, normally without paintwork. Good luck.
Car: 1992 Camaro Z28
Transmission: 5spd.
Bro, Bro, Bro..... before any drastic changes check your "bump stops"!!! That was my problem w/ 17x9.5 in the rear TT II's! The shocks were also dead, the bump stops were my main problem! It figures, I spent like 500 plus dollars on shocks etc, and it was the $50 bump stops!
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I had to replace my springs and shocks nad bump stops. No more problems and I left my fender as is. Kinda glad because i probably would not of replaced the shocks had that not happened.
Guest
Posts: n/a
i have that exact same problem!!!!
i have ZR1's with sportlines.. and the back right rear has been sliced too!!! damn things.. but im changing shocks AND bump stops soon.. i frickin hate the sound it makes.. its bad..
im also putting in a adj panhard bar to recenter the rear end.. its needed badly.
Car: 91 Z28
I just installed global west LCAs and relocation brackets yesterday, alsong with an adjustable panhard bar. And I do have bump stops. so I guess I will have to take it to a shop and have them role the fender? annyone know how much this will cost me? I really don't want to grind the inner fender down. keep the options coming. thanks
Car: 91 Z28
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I think it cost my buddy around $100 to have his rolled. I wouldnt grind anything, just knock it in with a hammer. Its easy, takes about 10 minutes, and its effective.
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Rolling a wheel well is easy. You just use a baseball bat and work the lip up a little at a time by prying against the tire.
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
You need an adj panhard bar to recenter the rear end, and rolling the fender lip helps too.
I'm runing 17x11's with 315x35x17's with no rubbing at all.
I did roll the fender lips and push in the inner fender wells to get them to fit with out rubing.
morrow
Jan 13, 2024 12:29 PM
84 TA NV
Sep 6, 2015 08:02 PM
