gettin rubber off paint.
Old Aug 1, 2004 | 10:21 AM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
wel i got a ton of rubber on the painted surfaces around my wheels. any way to get this stuff off?
and yes its from burnouts. lol
Old Aug 1, 2004 | 12:42 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
umm....
go pick up some bug and tar remover spray from AutoZone or Wal mart, then pick up a clay bar kit (Meguiars? Mothers?) and you should be set :-P
Old Aug 1, 2004 | 05:18 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Turtle Wax bug and tar remover, alot of junk rags, and patience. Look in my sig, I feel your pain
Old Aug 2, 2004 | 09:20 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
WD40 also works.
btw, if you spray wd40, Pam cooking spray, or some other oil like stuff behind the wheels, the rubber can be wiped off when you come back to the pits.
Old Aug 2, 2004 | 04:25 PM
kwyjibo's Avatar
Car: 1987 ford mustang gt
Engine: 5.0
Transmission: tremec t-5
i had my rear quarter absolutly covered with road tar,
i stoped at a light on a patch apparently, it was raining so i didnt gun the gas either, and my tires spun like i actually owned a big engine, i knew that wasnt good, when i got to school i loooked at the back and noticed it, i couldnt do anything about it till i got it home, when i did the stuff was dried and hardened on my car, i foolishly tried a wet paper towel on it and it ripped the towel,
anywho long story short i use some household sented keroseen that my parents had left in a old lamp, it striped the tar right off my car and didnt hurt the paint, ive never really used it on rubber, as i dont have a problem with burnouts with my car, but i think it would be a worth while try if youve got soem around the house or can get some cheaper than those tar/bug removers
Old Aug 2, 2004 | 05:11 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Lacquar thinner works wonders...Im not even kidding!!
Old Aug 2, 2004 | 10:06 PM
Borsty's Avatar
Car: 89 Trans am
wont wd 40 and lauqour thinner hurt paint?
Old Aug 2, 2004 | 10:17 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
All laquar thinner will do is dull out ur paint u just have to wash and wax again. I use it on my car all the time...try the bug stuff first then laquar if u cant get it off...
JAson
Old Aug 3, 2004 | 04:44 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
<off topic> by im lovin that signature. :hail:
Anyway, i dont think wd40 hurts paint at all. Also, teh bug and tar remover works for the rubber on the tires also and not just "tar"? I mean when the rubber gets caught onto the 1/4's.
Old Aug 4, 2004 | 08:56 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
WD40 will NOT harm any paint.
Old Aug 6, 2004 | 05:35 AM
JACKO's Avatar
Stay away from Laquer thinners! IMO, I use Eucalyptus oil, but then I live in OZ so not sure if you guys can get it?
wd40 ain't too bad either,
If I know I'm going to do a burnout I spray around the wheel arches with canola cooking spray (it puts a non stick film over your paint)
Old Aug 6, 2004 | 01:58 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
gasoline also works well to remove rubber and road tar.. just damp a cloth and rub your rear quarters..
wash and re-wax after for the gas strips off the wax.
canola cooking oil or similar is a great preventative measure before burnouts (if the burnouts and flying rubber are planned in advance!)
Old Aug 6, 2004 | 02:44 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
so like i said.
a can of PAM cooking spray.
Old Aug 14, 2004 | 01:00 PM
Borsty's Avatar
Car: 89 Trans am
the turlte wax bug and tar **** didnt work for anything
Old Aug 14, 2004 | 01:27 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
try gasoline, then of course wax that area a.s.a.p
loud91rs
Oct 5, 2015 10:05 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
gta_knight
Sep 23, 2015 04:59 PM
