new SLPs
Old Aug 1, 2004 | 10:54 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
new SLPs
does anyone have the new for third gen 17 in wheels? im considering them but would like to see how they look on someones ride (preferably a formula) before i drop the cash.
Old Aug 1, 2004 | 11:09 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
ummm... their is a silver bird runnin around here somewhere... with the light silver SLP zr1's
Old Aug 1, 2004 | 11:53 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i;'m considering them also but the hyperblack ones ...i need pics too i want to see how the 8" width looks on the car.
jeff
Old Aug 2, 2004 | 12:45 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
jeff
The 8" wide wheels will look exactly the same as most 3rd gen wheels. With the exception of early TBI and V6 models most 85 and later 3rd gens had 16x8" wheels.
Old Aug 2, 2004 | 01:31 PM
nolanr0413's Avatar
Car: Trans am
buy the rims and then have the rear rims widened to like 9 or 10 inches, then you would have some good looking rims with a wide rear tire.
Old Aug 2, 2004 | 01:43 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Or you could just use the 9" or 11" 4th gen/vette versions with a spacer. It may even be cheaper that way.
Old Aug 2, 2004 | 05:23 PM
JeffW's Avatar
Engine: 305 tpi LB9
how do you get them widened? that would be super cool if it could be done.
i hate spacers so no 4th gen rims for me
Old Aug 2, 2004 | 05:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
They cut the wheel, add a slab of material and re weld. It is a tremendous amount of work when going with 4th gen reas is so much easier. You could even go with a 4th gen rear and not have to use spacers. Even that would be cheaper.
Old Aug 2, 2004 | 06:01 PM
JeffW's Avatar
Engine: 305 tpi LB9
ok if 4th gen rear then slp rims will still be 8" and ss 5 spokes or zr;s would still need front spacers, or slp on front would not match the rears.
who does the rim widening thing and has anyone done it?
And what does that do to back spacing, gues it would have to be qa carefull measurement or back to the original problem with fitment.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
