Does this wheel info sound right to you guys?
Old Aug 30, 2004 | 08:11 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
My parents are tellin me that this wheel combo will not work and is gonna scrub on every turn........not only that but they said it was gonna mess my front end up. Well I just turn my nose up to that and would really fell better trusting your opinions(i know im close to being right).
Im gonna be getting the Boyd Coddington Daytona wheels with the "Soft Lip".
Front:18x8 With 4.75bs on 245/40/yr18(not sure what brand yet).
Back:18x9.5 with 5.5bs on 275/35/yr18
Now for you guys that know your rims and tires does this sound like a workable combo? Do the tire sizes sound right? Can they be alittle bigger without fear of scrubing? Im very open for suggestions.......remember this car is gonna be a daily driver not a weekender so I would like to have tires that will protect the wheels.
I'll be getting the wheels ordered just as soon as I can get to the bank to borrow the money.....that'll probably be a few weeks(2-3). So I'll bump this up every couple days or so to try and get the most feedback as possible.
Thx for taking the time to read:lala:
Attached Thumbnails Does this wheel info sound right to you guys?-daytonalarge.jpg
Old Aug 30, 2004 | 08:49 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I don't see a problem with this combo. I have seen it many times on cars without a problem. It is cutting it close but it should work. Your ok in the rear, the front is going to be close but will work. Good luck. If your tire shop is like the one I work at they'll try it on for you FIRST, then if it clears then go for it.
Old Aug 30, 2004 | 09:29 PM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
Hey I don't want to hijack this thread in any way, but will that combo work but with 18x9.5 in front (as well as the back). The wheels I want are only available in 18x9.5. I could roll the fender and beat on the frame a little, would that make it work?
Old Aug 30, 2004 | 09:32 PM
KonArtist's Avatar
Engine: 350 HSR
Axle/Gears: 3.42's
When you say im cutting it close what do you mean? Tire, wheel, or both? Could you possible suggest changes that would bump me over alittle more over into the safe side?
Thx for your time
Old Aug 30, 2004 | 10:16 PM
The width of the rim is fine. The 18X8 will work. The 4.75BS should work. The tire is fine up front. If I am doing it right(calculating it)it should fit just inside the wheel well with no rub. Now if you go wider in the front(tire)well there will be some rub. A 245 is probably a safe bet to be the "max". If you put something bigger(255)that may be too close for comfort. I would stick to this current setup.
Kbeez stick with a 17X8 up front unless you plan to go bigger on the tire then you will have to get a bigger rim to set the beed correctly. 18X10.5 is do able but it all depends on the look, I don't lkike the way it bubbles out of the wheel well, so I would go 18X8 up front.
Also you can't rotate your tires anymore.
Old Aug 31, 2004 | 03:30 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
I run 275/40-17's on front and rear. I occasionally get some rubbing of the front drivers side wheel when turned to the lock and backing up over an uneven grade. I've looked to see what it is and there's a plastic rivet that gets snagged a bit by the corner of the tire. In my view, it's no big deal. My next set of tires will be 275/40-17's again. The 18's should be no different. HTH...
Old Aug 31, 2004 | 06:26 PM
nolanr0413's Avatar
Car: Trans am
i have boyd rims , same size as yours but my backspacing is 4.5 in the front . Heres a pic of them .
Attached Thumbnails Does this wheel info sound right to you guys?-100_0876.jpg
Old Aug 31, 2004 | 08:09 PM
As you can see on Nolans car, the little change in Back Spacing will work for you.
Damn I love your car Nolan. Can I have it? lol
Old Aug 31, 2004 | 08:35 PM
nolanr0413's Avatar
Car: Trans am
sure you can have the car , just come over and pick it up whenever you want... lol.
as far as your parents thinking it will rub , i can see the concern but they wont rub at all . I have the same specs as crazyhawaiian . So me crazy and kandied you can all talk to about what bs you need . But with the 4.5 and my drop i dont have any probs.
Btw have you checked out the hot rods for a set of rims.
Old Feb 9, 2005 | 10:22 PM
Knight350's Avatar
Hey Nolan, the car looks great with those wheels, very clean!!
I have a 91 gta... soon to be painted electron Z06 blue... but I wanted to ask about your wheels, if you don't mind.
How much did you pay for them? Are they 18"?
And what is the backspacing on the rears?
Did you need adaptors or anything?
and how do you find the ride quality now?
Thanks man, sorry about all the questions, I just need to figure out how this whole backspacing thing works!
Thanks again, have fun!
Old Feb 10, 2005 | 10:35 AM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
well being an older post and nolanr being banned (cept he got a new name).....bah too confusing Ill just try and answer the questions....
they are 18"....same as the first poster wanted
5.5 is rear bs
no adapters...Boyd Coddington fabs up each wheel custom
cant comment on ride quality til I get my hotrods from Boyd (prices can be found at sportruck.com....if thats where he got his from.....nolanr I hope I did alright
Old Feb 10, 2005 | 08:47 PM
Knight350's Avatar
Heh heh, Thanks very much Camaro!
That's what I wanted to hear! Well except the part where he got banned...
I'll check out the prices, thanks again!
B_Dubya
Aug 26, 2015 05:09 PM
Street Lethal
Aug 14, 2015 08:25 PM
gta power
Aug 13, 2015 06:15 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
