Found a good site with tips n pics on using VHT Nightshades on tail lights.
Old Sep 20, 2004 | 11:14 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://www.corrado-club.ca/mods/tailtints.html
Its been talked about using Nightshades here but no good direction.
Old Sep 20, 2004 | 11:41 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I know that a Ford car but there is a mod somewhere around here to use those and the euro version of them tail lights on a 3rd gen Camaro.
Old Sep 21, 2004 | 12:38 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
You mean like this? I havent gotten around to polishing them but testors makes some black tinted clear and its like.. 1/5 the price of niteshades FYI
The car on the website is a VW btw.. not a ford
Old Sep 21, 2004 | 01:45 AM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
I would have sprayed the reverse lights also if I were you, it looks off.
Old Sep 21, 2004 | 09:12 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
that would be illegal. reverse lights have to be clear. it would be cool if you could though. I would paint them and the amber lights all red.
Old Sep 21, 2004 | 12:02 PM
Car: 92 Z28
That was the initial plan but the red turned out fairly pink and not very translucent, so I had to do something, I'm going to graft another clear section in place of them if I can ever find a cheap pair grid lights
Old Sep 21, 2004 | 12:54 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
replacing the amber with white/clear seemed to be the best option without tearing the lights completely apart, but IMO it's too much white. Though the grids might help it out a little...
Attached Thumbnails Found a good site with tips n pics on using VHT Nightshades on tail lights.-oldlightsnew.jpg
Old Sep 21, 2004 | 03:44 PM
Car: 92 Z28
hmm maybee ill do red.. I need to get some lights first
Old Sep 21, 2004 | 04:16 PM
Car: Camaro
Engine: 3800
and red with IROC lights but no lines:
Old Sep 21, 2004 | 06:26 PM
Car: 92 Z28
Yes the red does look better. Did you do those yourself? If so please clue me in I was just planning on cutting out the pieces with a dremel, gluing them in and then sanding and painting the inserts again.
Old Sep 21, 2004 | 06:58 PM
Car: Camaro
Engine: 3800
Photoshop.
I'm in the middle of doing some tail light stuff, but I got side tracked fixing things on the car rather than making stuff for it.
-Bud
Old Sep 21, 2004 | 10:28 PM
digital_burnout's Avatar
Car: 91 camaro z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 410
hows this look? i Think it looks good.
Old Sep 21, 2004 | 10:49 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
too much black, and seriously illegal. your gonna get nailed for that one. hope they don't cath on to it
Old Sep 22, 2004 | 08:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I may just try to sand n clear coat option myself. Long as I can get ride of the white out or haze and get them shiny again, I don't care about making them darker. Lights are meant to be seen.
Old Sep 23, 2004 | 02:23 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ohh I never showed you what I am dealing with.
Old Sep 23, 2004 | 05:27 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I ended up just wet sanding and clear coating them.
its all I really wanted was a nice shiny look.
I did a 220 320 600
Then clear coated them well.
Sun baked so they would dry fast.
I stuck the images all on one page.
They look really nice.
Dial up friendly.
http://www.viragotech.com/taillights.html
Old Sep 23, 2004 | 05:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Site wont let me edit so double post.
I did a 220 320 600
Before
After
Dial up friendly.
Old Sep 23, 2004 | 05:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
One thing that really helped and I did not know. The tail lights come apart. Its not easy for the gasket sealer they use but with little effort the lenses come right off. Much easier to work with apart.
Old Sep 23, 2004 | 08:03 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
is this what you mean?
http://memimage.cardomain.net/member.../244174_53.jpg
iroc2nv
Old Sep 23, 2004 | 08:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
iroc2nv
Yep, them ugly things.
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
