over spray on inside back window help ASAP!!!!
my 85 trans am was paitnted years ago and i am finally done putting everything back together(prts are hard to find) mothers mag and alluminum wont get it off so i doubt wax would any suggestions? BTw car does not have rear window defrost
Car: Old man car till I get another 3rd Gen
Engine: at least it's a V8
Transmission: Wrong wheel drive. Makes no difference to me.
A sharp razorblade at a shallow angle is the fastest way to remove overspray from glass. Take a new blade, hold it at a shallow angle to the glass, and scrape it back and forth like you would filet a fish. As long as you use a new blade, it should come right off, and not damage the glass at all. This only applies to vehicles without defroster grids though. Cleaning overspray off of windows with defroster grids is much more difficult.
Car: Trans Am "GTA"
Yes, a razor blade will be your best choise. The fastest & cleanest.
just make shure you take your time, do everything slow & dont rush it. Like stated before as long as the blade is new the only thing that can scratch the glass is the corners of the blade.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
do you have rear defrost?
if you do forget the razor blade or forget the defrost working when your done. goof off works good they have a overspray remover on www.autobodystore.com i have some and it is nice.
Jeff
Jeff
Engine: 305 tpi LB9
Originally posted by CaysE
LOL... come on, his post isn't THAT long! He said he doesn't have defrosters.
thanks alot guys i used a razor blaze and a touch of rubbing compound and a lil elbow grease and got it off, i tell ya my bodyman can lay a mean coat but hes not to kind to interiors
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
