Changing to a 90+ Bird front end
Old Oct 5, 2000 | 12:01 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
My friend just fricked up my front-end and fender of my 89 bird. The fender I'm sure can be banged out, but the front clip is ripped up pretty bad.
Anyone know a good source to get the "Demon Eyed" 1990+ front clip.
How much else do I have to replace? Prbably just the support, right?
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, Demon Carb, Phase VI Chevy Bowtie heads, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto For the road: minor motor, more suspension stuff. MODS
Old Oct 5, 2000 | 12:53 AM
admrlam's Avatar
Noooooooooooo! Not the Shark Nose!!!! EEeewwwwwwwww... Okay, now that that is out, a good place to get them is
1. classic industires, at classicindustries.com (order a catalog)
2. http://www.fenderent.com/
1988 Formula, 305TPI, 700r4(for now), headers, stage 2 PROM, modded MAF, cat back, no catalytics, cowl hood, centerline champ 500 rims, KOBEL predator ground effects kit, Trans AM tailights, dash pouch, 92 shift console w/indicator, white face gauges, accented red trim, 12 speaker stereo, 4 amps, tint, T tops... icq 44373460 AIM:admrlam
see it at www.geocities.com/admrlam/bird.html
Old Oct 5, 2000 | 09:15 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
They "shark nose" as admrlam so called it, was only available on 91 and 92 birds. And the ground effects are completely different. So you will want a nose from a formula so it doesnt have the ground effect piece on the nose. Most of the plain birds rolled off the assembly line with the sport appearance package in 91 and 92.
James
If the women don't find you handsome they should at least find you handy
[This message has been edited by scooter (edited October 05, 2000).]
Old Oct 5, 2000 | 04:15 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
I thought they are pretty cool. Plus, I can do some cool alterations with the light set up. Just thought it would be different.
Thanks for the info, guys. I definately will have to get the formula one since I do not want any ground effects.
Old Oct 13, 2000 | 01:14 PM
MILT's Avatar
FYI I think you'll need that waffle/shock absorber thing the fascia mounts to, and you'll need the 91-92 head light assemblies as well.
Old Oct 13, 2000 | 05:58 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
The support I will need, but why do you say headlights. I know I'll need the fog light mounts and such, but the headlights and hoods on the cars are the same.
Old Oct 13, 2000 | 06:14 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The headlights ARE different. None of the part numbers cross refrence in the GM computer. Believe me I tried.
James
Old Oct 13, 2000 | 06:24 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Is the hood different
Old Oct 17, 2000 | 09:46 AM
Pino91Formula's Avatar
the hood is the same , and you can use the head lights , you just need to change the the black plastic housing around the light it self
Old Oct 22, 2000 | 06:53 AM
84FIREBIRDTA's Avatar
WHAT ABOUT ADDING THE "SHARK NOSE" TO AN 84
Old Oct 23, 2000 | 07:01 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
84.....89.... same deal
Old Oct 24, 2000 | 01:45 PM
'89Formula305TPI's Avatar
graebz28, are you sure that 'shark nose' will fit to an '84 bird.
If you compare an <-85 and 85-> bird, I would say that them got a little difference in the whole front fender assembly, not to mention the front end it self.
Just an opinion.
'89 Formula 305 TPI T-5
Check out my car HERE!
Now, go and click them banners!
Old Oct 24, 2000 | 04:27 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Good point.
I think that the fenders are the same from 82-92?!?
If they are, then they have the same mounting bolts to mount any front end. But the plastic backing behind the front clip(in any situation) would have to be replaced with everything else that is mentioned above.
If not? I do not have an honest answer.
Old Oct 25, 2000 | 08:25 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
The fenders are the same but you will have to get the metal bumper, nose, support piece that goes on the part where the hood latch is, turn signals, foglights and possibly a few other pieces. I am doing the process myself but I need a few more things.
James
Old Oct 25, 2000 | 12:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, I've got an '84 clip on my '86 Firebird...
The fenders are the same. I have '84 fenders on my '86. I noticed some upper-frame-rail bolt-hole alignment problems, but I also had framework done. I just notched the '84 fenders.
The '84 nose has a different style of "honeycomb" impact-absorber between the steel bumper and urethane nose. When I found the "correct" '86 nose, I took off my '84 unit, but the correct one wouldn't go over the honeycomb. I had to remove the extreme ends of the honeycomb... you'll see what I mean if you go thru with this.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
kyleb24
Aug 15, 2015 08:24 AM
