paint the pulleys or not
Old Oct 21, 2004 | 11:27 AM
Buck89RS's Avatar
Car: 1989 RS
Engine: 2.8L MPFI Bored 30 over (Rebuilt DEC 2004)
Transmission: 5 - SPD With 3.42 open rear end
I have painted the block, heads, valve covers, and oil pan GM blue. I want to know if i should also paint my pulleys blue or leave them black. I will let this thread decide. Thanks
-Buck
Old Oct 21, 2004 | 12:09 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
got any pics of what youve done so far?
Old Oct 21, 2004 | 12:12 PM
Buck89RS's Avatar
Car: 1989 RS
Not yet, but when im done i will be posting them.
Old Oct 21, 2004 | 12:16 PM
Engine: 283
well i think its kinda hard to picture your block with everything painted....what im thinking,id just leave them black...but its your ride,you do what you want to do! good luck with everything!!
Old Oct 21, 2004 | 01:42 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
you need some sort of contrast, leave them black, better yet get a set of polished pulleys! :lala:
Old Oct 21, 2004 | 01:55 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Paint them! but paint`em black...colored pulley`s look like puke
Old Oct 21, 2004 | 02:15 PM
Buck89RS's Avatar
Car: 1989 RS
What if i stripped all the black paint off the pulleys i have and clear coat over the bare metal(so it wont rust)? How would that look?
-Buck
Old Oct 21, 2004 | 02:39 PM
probably like gunmetal grey with wd-40 sprayed on it
Old Oct 21, 2004 | 02:54 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I'm still working on this site, so be patient, but it is about the changes I have done to the engine bay as far as looks only....
Raif engine details
I have a candy apple painted block, tranny, heads, oil pan, lower intake and runners....
What I did was replace what I could, pulley wise, with billet pulleys...or got some billet pulley covers. The rest were painted candy apple red...I threw in some chrome touches to help keep things balanced...There was very little black remaining...but I painted my engine bay satin black, so the C.A.red is contrasted against that.
To answer the clearing of stripped pulleys....nope. I would not recommend it. I have had tons of probs with the red chipping thru normal wear and tear and maitenance...
See if your clear chipped, it would rust...so you would have a nice pulley with rust spots...
Old Oct 23, 2004 | 09:08 AM
tomwilson's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: Th-700r4
are those strut towers polished?
Old Oct 23, 2004 | 01:49 PM
redraif's Avatar
No they were diassembled & chromed then reassembled!
Old Oct 23, 2004 | 05:13 PM
LT1guy's Avatar
Car: 1987 Trans Am
As Redraif said, we painted some of the pullies on her car...and frankly I'll never do it again. The pullies practically chip before you can get them on the car. Its too much work for something that will get chipped in no time.If you have to have colored pullies (no aluminum ones available for your application), powdercoat them.
Old Oct 23, 2004 | 09:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
(stupid alt belt rubbed my paint off)
Old Oct 23, 2004 | 10:18 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I would leave them black. Too much accent color can be a bad thing. :nono:
Old Oct 24, 2004 | 01:50 PM
pskel350's Avatar
when i first put my engine together i painted all the pullies....big mistake. the paint would actually start to move and fly off the surface at extreme rpm's. the next winter i had mine bead blasted and powder coated. well worth the money, dont waste time by painting them
Old Oct 24, 2004 | 07:40 PM
CaysE's Avatar
Get them anodized blue if you really want color. Otherwise, I'd get them polished.
Hotrodboba400
Dec 10, 2019 07:07 PM
BDR
Nov 7, 2015 03:05 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
